Honda S2000 Honda S2000
Wheel option
Old May 20, 2010 | 05:23 PM
TheYellowDart's Avatar
Default Wheel option
Looking at buying a set of Konig Lightning 18X9.5 45GBL with 265/35 for rear and 18X8 35GBL with 225/40 for rear. My question is will this wheel and tire package fit correctly? Is it the right offset? New to the whole s2000 thing. Thanks in advance
Old May 21, 2010 | 09:07 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Wheel option
That should fit, but it is a little bit aggressive. Is that what you want? You will def have to roll the fenders depending on your height.
Old May 21, 2010 | 09:53 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
and ull have to relocate the bumper tab
Old May 21, 2010 | 09:54 AM
S2KILLA's Avatar
ohhh and ull have to run some negative camber depending on how low you are...
Old May 21, 2010 | 02:10 PM
ok I am not wanting to have to roll the fenders what is a size that would allow that? I am stock height now but plan on getting something adjustable.
Old May 25, 2010 | 03:09 PM
Black Nugget's Avatar
Have you bought these yet or are you still looking for a bit of assistance?
Old May 25, 2010 | 05:31 PM
JDMF22B's Avatar
I think unless you're at stock height, and similar oem offsets you're going to need to roll your fenders / bumper tabs / fender lining if you're doing 18"s. Someone correct me if I'm wrong. Oh, and you'll definitely need to run some negative camber
Old May 25, 2010 | 06:27 PM
I am still looking for wheels. I guess my question would be what is a good wheel and tire option if I cant go with 18in then i wont. I would rather not roll the fenders or run any type of camber. I am at stock height right now but plan on getting something adjustable.
Old May 25, 2010 | 07:20 PM
JDMF22B's Avatar
First off is it an ap1 or ap2? Also, if you're planning on lowering it camber is going to be necessary. I believe US spec is F:0 R:-1. UK OEM spec is F:-1 and R:-2. I'm running oem wheels w/ skunk2 springs and I can't go any HIGHER than -2.8 in the rear
Old May 25, 2010 | 07:36 PM
its an ap1.
Old May 25, 2010 | 07:47 PM
JDMF22B's Avatar
http://www.s2ki.com/forums/index.php?showtopic=342793
You should review that article / guide.
One thing to note, the ap1 oem rear tires aren't actually real 225's. They are sort of mislabeled. You're gonna wanna a run a 245 in the rear if it's not the OEM tire. Past what I've said already, I'm really of no use so hopefully someone else can chime in
Tsokolate EG
Honda S2000
26
Mar 22, 2013 02:52 PM
.Ryan
Honda S2000
Nov 2, 2009 06:49 PM
accord03coupe
Honda S2000
Apr 6, 2009 07:09 PM
hotcivicsi
Honda S2000
22
Apr 5, 2009 06:00 AM
Ashen s2000
Honda S2000
Dec 9, 2006 07:57 AM
