wheel and tire help
Old Jul 1, 2011 | 06:13 AM
meric0786's Avatar
Default wheel and tire help
Ok guys imma running a 92 eg bubble with a 4 lug. I want to run a 15x8 wheel with a +0 offset. Will I have any issues running a 225-50-15 with this offset. Def will be rolling front and rear fenders. I did read I may have to put a spacer in to avoid rubbing on the rear trailing arm. Was just wondering if this offset will work
Old Jul 1, 2011 | 06:25 AM
kyden's Avatar
Default Re: wheel and tire help
you're gonna have to run a lot of camber or do quite a bit of pulling to get that to fit.
Old Jul 1, 2011 | 06:56 AM
toyomatt84's Avatar
Sanji
Well, without fender flares or an unsafe amount of negative camber, there still won't be enough clearance for a 0 offset 8" wide wheel for your car.
Old Jul 1, 2011 | 07:44 AM
meric0786's Avatar
Ok that was what I had thought what is ideal offset for this size tire wheel package
I have a set of 03 si wheels with **** tires on them but what I would like to know , are they 6.5 or 7 inches wide. If so can I run a 215-50-15 with no issues
Old Jul 8, 2011 | 02:19 PM
meric0786's Avatar
Can I run a 215-40-16 with no rub issues. The wheels will have a 38mm offset . Do the fenders need to be rolled
Old Jul 8, 2011 | 06:34 PM
JGallamore's Avatar
everything that ive read and searched for on here says that a +36 offset works the best in a 15x8.
Old Jul 8, 2011 | 10:27 PM
toyomatt84's Avatar
Sanji
You'll probably need a slight amount of rolling to clear those tires at all times. But, they'll fit the car safely.
Old Jul 10, 2011 | 07:47 AM
meric0786's Avatar
No way to use a 225 with a 16 in wheel? Def gonna roll fenders anyway.
Old Jul 10, 2011 | 11:16 AM
toyomatt84's Avatar
Sanji
The only way you could run a 225 with a 16" wheel, would be with 225/35/16's. And that is a tire size that I don't think exists. If you want 225's, you'll have to go with 15" wheels for your car.
CWBETB
Apr 25, 2012 02:47 PM
blackened02
Honda Civic (2001 - 2005)
Jul 27, 2010 09:19 PM
integrawow
Dec 14, 2009 06:55 PM
HamiltonRex
Oct 12, 2005 11:56 AM
spock_rocker
Feb 6, 2004 03:08 PM
