Honda S2000 Honda S2000
wheel offset.
Old Nov 9, 2005 | 05:18 PM
iHATEspeedbumps.'s Avatar
Default wheel offset.
ive been all over s2ki searching. couldnt find anything. will a 16x8 with a 25et fit on the s2ks rear? and a 16x8 35et fit on the front? TIA
Old Nov 9, 2005 | 05:28 PM
WowOzYouRock's Avatar
Default Re: wheel offset. (iHATEspeedbumps.)
the front works with BBK ... but the back is no good
Old Nov 9, 2005 | 07:27 PM
Default Re: wheel offset. (Y2K_S2K)
so why will it only work with a bbk in the front?
Old Nov 10, 2005 | 05:00 AM
papa5murf's Avatar
if you want to run a bbk in the front.. you're looking for an offset of +36 on most wheels... however that number could be higher if you have a wheel that has spokes that stick out a bit....
for the rears... you want something that'll clear the fender without rubbing (so having the highest offset in the rear is key) since you want to run wider tires...
b20forlife
Jun 26, 2012 05:47 PM
TL1000R
Honda S2000
17
Jun 16, 2012 01:06 PM
b0yg0tskills
Feb 16, 2010 06:34 AM
bbRedSi
Honda Civic (2006 - 2015)
May 6, 2007 11:38 PM
HamiltonRex
Oct 12, 2005 11:56 AM
