Honda S2000 Honda S2000
Check Engine Light
Old Dec 13, 2007 | 10:13 AM
Jordan_Cohen18's Avatar
Default Check Engine Light
I have a 2002 s2k, just bought it a week ago, 57,000 miles,
Check engine light just came on for no reason, any ideas??
Old Dec 13, 2007 | 10:16 AM
2K2S2K's Avatar
Default Re: Check Engine Light (Jordan_Cohen18)
Check the gas cap.
Old Dec 13, 2007 | 10:23 AM
TheDancingPill's Avatar
Default Re: Check Engine Light (2K2S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2K2S2K &raquo;</TD></TR><TR><TD CLASS="quote">Check the gas cap.</TD></TR></TABLE>
make sure you click it at lease 3 times
Old Dec 13, 2007 | 02:23 PM
megalomaniac001's Avatar
Default Re: Check Engine Light (TheDancingPill)
take it to an auto parts store and get them to read the code. seach CEL on this forum and see what the code relates to. Then, fix it. Easy like 1 2 3
Old Dec 13, 2007 | 02:50 PM
jefferyg32's Avatar
Default Re: Check Engine Light (megalomaniac001)
Gas Cap code
Random Misfire code
Cat Converter code
Its more than likely one of those.
But YES go get it scanned so you know for-sure.
Old Dec 13, 2007 | 04:55 PM
marks_lude's Avatar
Default Re: Check Engine Light (jefferyg32)
just to check, ur not making the assumption the 'maintainance req'd' light is the same as a CEL are u... main. req'd comes on periodically to indicate time for an oil change.
Old Dec 14, 2007 | 06:34 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Check Engine Light (marks_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marks_lude &raquo;</TD></TR><TR><TD CLASS="quote"> main. req'd comes on periodically to indicate time for an oil change.</TD></TR></TABLE>
wrong
Old Dec 14, 2007 | 08:02 AM
cherrynutz's Avatar
Mine came on a little while ago. Took it in (certified) and it was a faulty gas cap.
Old Dec 14, 2007 | 08:27 AM
m R g S r's Avatar
Default Re: Check Engine Light (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
wrong</TD></TR></TABLE>
what do u mean wrong? he is correct it comes on after a certain amount of miles...i think its 7k...sorry not sure on the number.
Old Dec 14, 2007 | 08:35 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Old Dec 14, 2007 | 09:02 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Check Engine Light (S@nt0s)
wrong because it has nothing to do with the oil.....it is a built in mileage meter for your "by the book" regularly scheduled maintenance, and does come on after X amount of miles after being reset
honda uses it as a tool to entice you to bring the car in for their regular scheduled maintenance intervals and supposedly when it was introduced was "supposed" to only be turned off by the dealership after the regular scheduled maintenance was performed, although now it has become apparent that honda figured out any joe shmoe could turn it off
Old Dec 14, 2007 | 09:12 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
true however i was agreeing with the fact that it comes on after X amount of miles which a new person can mistake for a CEL.
and yes it does not come on to say oil needs to eb changed but it can be used for that very purpose as a reminder to the owner.
Old Dec 14, 2007 | 09:17 AM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">true however i was agreeing with the fact that it comes on after X amount of miles which a new person can mistake for a CEL.
and yes it does not come on to say oil needs to eb changed but it can be used for that very purpose as a reminder to the owner. </TD></TR></TABLE>
i use it as a reminder to make sure everything is still perfect so my performance doesn't deteriorate into that of an ap1
Old Dec 14, 2007 | 09:21 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
i use it as a reminder to make sure everything is still perfect so my performance doesn't deteriorate into that of an ap1 </TD></TR></TABLE>
GRAF-FITI's Avatar
* B A N N E D *
Old Dec 14, 2007 | 09:54 AM
envee's Avatar
Is it turned off the same as previous hondas? Under the driver's side dash?
Old Dec 14, 2007 | 09:59 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (envee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envee &raquo;</TD></TR><TR><TD CLASS="quote">Is it turned off the same as previous hondas? Under the driver's side dash?</TD></TR></TABLE>
no, its a key turn button press trick...
put the Key to "on" and at the same time press trip/reset button at the same time and it will reset....
man its been a long time...
Old Dec 14, 2007 | 10:09 AM
envee's Avatar
Well they are trying to make it a little trickier.
Old Dec 15, 2007 | 04:22 AM
marks_lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">wrong because it has nothing to do with the oil.....it is a built in mileage meter for your "by the book" regularly scheduled maintenance, and does come on after X amount of miles after being reset
honda uses it as a tool to entice you to bring the car in for their regular scheduled maintenance intervals and supposedly when it was introduced was "supposed" to only be turned off by the dealership after the regular scheduled maintenance was performed, although now it has become apparent that honda figured out any joe shmoe could turn it off</TD></TR></TABLE>
well honda just stated it was for the oil in the owners manual. it even says, "if you change your own oil make sure to reset the light" in my 01 owners manual.
as i said, its mile intervals tho, so let it remind you of wahtever you want to be reminded of every x miles.
Old Dec 15, 2007 | 12:42 PM
Yea I Checks Gas Cap and it went off,
wow talk about rediculous haha
cool, thanks everyone
Firestarter
Oct 6, 2005 10:52 PM
idriveadelsol7
Aug 29, 2005 09:29 PM
Josh10e
Dec 13, 2004 06:59 AM
afterburners
Feb 2, 2004 05:18 AM
Mires
Jul 3, 2003 07:37 AM
