Check Engine Light, Code P1457
Old Dec 12, 2004 | 02:07 PM
Josh10e's Avatar
Default Check Engine Light, Code P1457
Anyone have an ideas how to fix this?
Old Dec 12, 2004 | 04:37 PM
86si's Avatar
Default Re: Check Engine Light, Code P1457 (Josh10e)
take it to the dealer, it is an evap. code most likely the cvs valve failed. I'm guessing its a 98-02 accord?
Old Dec 12, 2004 | 04:41 PM
drdisco69's Avatar
Default Re: Check Engine Light, Code P1457 (86si)
Make sure your gas cap is on tight.
Old Dec 12, 2004 | 06:13 PM
86si's Avatar
Default Re: Check Engine Light, Code P1457 (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure your gas cap is on tight. </TD></TR></TABLE>
code 1456 would be a loose gas cap. 1457 is for the canister system not the tank system
Old Dec 13, 2004 | 06:24 AM
JimBlake's Avatar
https://honda-tech.com/zerothread?id=748876
Look about 2/3 of the way down for my post about what to check out...
Old Dec 13, 2004 | 06:59 AM
drdisco69's Avatar
Default Re: Check Engine Light, Code P1457 (JimBlake)
Ah yes, a northern car. All the corrosion will cause this, it's one of the valves on the canister, the vent shut valve I believe. If you've got under 80k miles, it's probably under the federal emmissions warranty. I'd give the dealer a quick call to check.
Thanks for pointing out the gas cap is p1456.
Jordan_Cohen18
Honda S2000
19
Dec 15, 2007 12:42 PM
JDMN
Mar 4, 2007 07:27 PM
londonsupra
Jul 7, 2006 05:30 PM
1998_4dr_gsr
Jan 24, 2006 05:03 PM
social_control
Nov 18, 2003 04:39 AM
