Honda S2000 Honda S2000
air pump bypass ???
Old Apr 22, 2007 | 08:23 PM
B18C1CYA's Avatar
Default air pump bypass ???
Well I have searched and have not realy got the answer I need , this is for all you turbo s2000 owners , what did you do with the air pump that used to connect into the intake tube ???? right now I took out the pump and hoses , but do you cap them or what ???? TIA
Old Apr 22, 2007 | 08:30 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: air pump bypass ??? (B18C1CYA)
Cap the end that goes into the intake manifold. Remember to pull the fuse.
Old Apr 22, 2007 | 08:32 PM
B18C1CYA's Avatar
Default Re: air pump bypass ??? (Mr. Projekt)
the vacum line ?? or the bigger tube ??? also where is that fuse located ?? Thanks
Old Apr 22, 2007 | 08:47 PM
* B A N N E D *
The big hose end that goes into the EGR valve. The fuse in the underhood fuse box, should be a 60A for Emission Air Pump.
Old Apr 23, 2007 | 06:31 AM
B18C1CYA's Avatar
will do , thanks
bakakuso2
Mar 24, 2009 03:04 PM
Hater01
11
Mar 2, 2008 08:30 PM
ttru98ex
Mar 24, 2007 12:01 AM
bo0sted
Mar 8, 2004 07:54 PM
Arturbo
Aug 2, 2001 10:10 AM
