Honda S2000 Honda S2000
Clicking...
Old Apr 21, 2007 | 08:34 AM
Otherguy's Avatar
NASIOC.com
Default Clicking...
Every time I start moving the car there is a clicking sound that comes from the rear of the car... does anyone have a clue as to what it might be?
Old Apr 21, 2007 | 08:52 AM
diewX3's Avatar
Rear axle problem.
Old Apr 21, 2007 | 09:10 AM
Otherguy's Avatar
NASIOC.com
Default Re: (diewX3)
well I just had them inspected, they said that they are fine
Old Apr 21, 2007 | 09:30 AM
LAS2K's Avatar
Default Re: (Otherguy)
broken final gears in the diff?
Old Apr 21, 2007 | 10:00 AM
Otherguy's Avatar
NASIOC.com
Default Re: (LAS2K)
I hope not, how can I check
Old Apr 21, 2007 | 10:07 AM
Otherguy's Avatar
NASIOC.com
Well, I think the axles might be moving around, Im going to re torque them down
Old Apr 21, 2007 | 10:43 AM
LAS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy &raquo;</TD></TR><TR><TD CLASS="quote">I hope not, how can I check</TD></TR></TABLE>
change your diff fluid...if you get chunks of metal and crap, then its time to open her up.
Old Apr 21, 2007 | 04:41 PM
Otherguy's Avatar
NASIOC.com
Default Re: (LAS2K)
how much do you think it would cost to repair?
Old Apr 22, 2007 | 03:36 PM
iam7head's Avatar
Default Re: (LAS2K)
clicking:
retroque the nuts to 220ft lb, it doesnt matter if it's new or not.
do you drive the car often? if not the rear pad could be sticking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy &raquo;</TD></TR><TR><TD CLASS="quote">how much do you think it would cost to repair?</TD></TR></TABLE>
for diff? 1000 ish
did it clicks when you are turnning or just clicking whenever moving?
Old Apr 22, 2007 | 05:20 PM
whitey's Avatar
Default Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">clicking:
for diff? 1000 ish
did it clicks when you are turnning or just clicking whenever moving?</TD></TR></TABLE>
Im having the same problem, but it only clicks when I turn regardless if Im in gear or not. What do you think it may be? Im hoping I just need to retorque the axle nuts.
Old Apr 22, 2007 | 06:41 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (whitey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitey &raquo;</TD></TR><TR><TD CLASS="quote">
Im having the same problem, but it only clicks when I turn regardless if Im in gear or not. What do you think it may be? Im hoping I just need to retorque the axle nuts. </TD></TR></TABLE>
Axle nuts.
Old Apr 23, 2007 | 12:01 AM
WowOzYouRock's Avatar
Default Re: Clicking... (Otherguy)
check and make sure the exhaust not hitting something... grab the exhaust tip (when its not hot, of course... if you did, then you are an idiot... ) wiggle it around and observe..
Old Apr 23, 2007 | 08:23 AM
tuan...'s Avatar
i have the same problem
clampjaw25
17
Dec 6, 2009 11:55 AM
Mr. Bagel
Honda S2000
May 13, 2005 09:39 AM
Kyles ej1
11
Sep 4, 2004 09:01 AM
InfamousGSR
Apr 16, 2004 10:17 AM
simplegreenmachine
Oct 6, 2003 06:33 PM
