Crankshaft wont turn?
Old Mar 28, 2009 | 03:07 PM
ganjasnack's Avatar
Default Crankshaft wont turn?
so i just had my motor built and i assembled it on a engine stand and installed my timing belt, set the timing and rotated the crank about 10 times to make sure everything was good. I put my tranny on, dropped the motor in and put everything together. Now when i turn the crank to set the timing for the distributor, the crank will only turn about a quarter turn and then stops. when i rotate it back and forth it sounds like its hitting somethin when it stops each direction. I took the timing belt off to see if it was gettin stuck on the valves but even when i turn just the crank it gets stuck. I am thinking it is something to do with the tranny or even my clutch and flywheel. Please help!
Old Mar 28, 2009 | 08:02 PM
blac00si's Avatar
Default Re: Crankshaft wont turn?
is your car in gear?
Old Mar 28, 2009 | 08:09 PM
93ls10.0's Avatar
even if you take the timing belt off you still have open valves
Old Mar 29, 2009 | 05:48 AM
ganjasnack's Avatar
not in gear and all valves are closed
Old Mar 29, 2009 | 07:12 AM
adrian1281's Avatar
Do you have a camshaft in the motor? Cause if you do, all the valves are not closed...
fcm's Avatar
fcm
Old Fart
I would pull the transmission and check it. 94
Old Mar 29, 2009 | 07:26 AM
ganjasnack's Avatar
yeah i took the cams out, i guess im just gonna go ahead and pull the tranny and see whats goin on down there, thanks.
Terry Langel
Aug 28, 2018 04:19 AM
starmedia
May 5, 2012 10:08 PM
kneeslide
33
Jan 31, 2011 10:00 AM
ganjasnack
Mar 29, 2009 05:46 AM
P1mpSlap
Jan 7, 2004 10:50 PM
