1999 ek1 engine timing
Old 07-31-2014, 11:16 PM
Roryz's Avatar
Default 1999 ek1 engine timing
how do i check engine timing?
and how do i fix it if it isn't correct, Thanks
Old 08-01-2014, 12:26 AM
shotoutacc0rd's Avatar
Default Re: 1999 ek1 engine timing
you take the timing belt off and install a new high quality belt following proper procedure if its off.
but before that you check the timing mark on the crank pully and the cam pully make sure both are top dead center aligned properly.
or do you mean, distributor timing? You take the bolt for the banana slide off and move the distributor until your car acts happy again.
Old 08-01-2014, 01:04 AM
I never narc'd on nobody!
NotARaCist's Avatar
Uh, none of that is correct.
Check the FAQ sticky - there's a write-up in there that will tell you exactly what to do.
bnwbass
05-14-2016 12:37 PM
journeyquest
08-31-2014 09:04 AM
zx92027xz
08-11-2012 06:47 AM
mfr1
08-25-2005 09:21 AM
Rostr02
08-11-2005 06:19 PM
Quick Reply: 1999 ek1 engine timing
