cyp sensor??
Old Feb 11, 2003 | 09:52 PM
Krayzielix's Avatar
Default cyp sensor??
hey sup i got a problem...my ecu threw a code 9..and i was wondering where the cyp sensor was located??..thanxx
btw i have a 93 d16z
Old Feb 11, 2003 | 10:00 PM
sgT's Avatar
sgT
Default Re: cyp sensor?? (k12ayz1e)
its in the distributor. you have to replace the distributor
Old Feb 11, 2003 | 10:10 PM
Qfactor's Avatar
inside the distributor. the first sensor with one tooth on it along with the its coil. the coil should measure between 350-700 ohms is the (ORANGE & WHITE). you can replace that one fualty coil with another if you have spare dis. from a different car. 92-up, if not you're going to have to get a new distributor assembly.
Krayzielix's Avatar
Default Re: cyp sensor?? (sgT)
aite..thanx man
SIDreamer
May 2, 2011 09:51 AM
Holistic28
Honda CR-V & Element
Apr 4, 2011 09:52 AM
raidacaipo
May 18, 2009 08:57 AM
YellowR2000x2
Mar 4, 2005 04:29 PM
Slatelude
Oct 13, 2003 05:26 PM
