code 14 wtf????
Old Dec 8, 2006 | 03:16 AM
BoBo Racing's Avatar
Default code 14 wtf????
hey guys whats up? i just got done putting the engine back in my R, and im throwing a cel. code 14 which is the idle contrl valve, the car wouldnt hold idle on its own i had to rig it so it would hold it. ive swapped out the ICV and same thing, still throwing the same code. so now i think i might have plugged in the wrong wire were the ICV might go. i know that theres 2-3 plugs that are the same plug as the ICV would u guys know where they would be i forgot??????
Old Dec 8, 2006 | 06:30 AM
GO-FIGHT-KILL's Avatar
You'd be throwing two codes if you had them mixed up.
If you mixed up TPS and IACV, let's say, you'd be throwing codes for both sensors.
Is the wiring damaged at all? Try one more IACV swap, maybe you just put on another bad one.
Old Dec 8, 2006 | 07:09 AM
RTW DC2R's Avatar
or try to clean out the IACV.
https://honda-tech.com/zerothread?id=1575913
Old Dec 8, 2006 | 09:47 AM
Default Re: (RTW DC2R)
and where again is the tps sensor. im on a chipped p28, also my throttle body and IM have been ported out idk if that would change anything? and last nite i tried swapping the two plugs on the throttle body i swapped them and nothing kept throwing the same code 14 and i swapped them back im running out of ideas here and it gets annoying driving the car like this
Old Dec 8, 2006 | 09:49 AM
RTW DC2R's Avatar
if you didnt have the TPS hooked up correctly, you wouldnt be driving the car at all. its the sensor on the side of the throttle body. the top sensor is the MAP sensor.
Old Dec 8, 2006 | 10:10 AM
neo_'s Avatar
I thought you bought a K20a
Modified by neo_ at 4:12 PM 12/8/2006
Old Dec 8, 2006 | 11:43 AM
b19coupe's Avatar
Default Re: code 14 wtf???? (BoBo Racing)
The IAT and the IACV use the same connector.
Old Dec 8, 2006 | 08:19 PM
Default Re: code 14 wtf???? (b19coupe)
what is the IAT???? and to NEO who said that this motor was back in the TYPE R maybe i put it in the ek hatch i got hmmm.... think about that
Old Dec 8, 2006 | 08:24 PM
b19coupe's Avatar
Intake Air Temperature sensor.
Old Dec 8, 2006 | 10:40 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBo Racing &raquo;</TD></TR><TR><TD CLASS="quote">and to NEO who said that this motor was back in the TYPE R maybe i put it in the ek hatch i got hmmm.... think about that </TD></TR></TABLE>
Then go post in the Hybrid forum section, this is the Integra Type R forum section. Ricer.
Old Dec 9, 2006 | 04:49 AM
Default Re: code 14 wtf???? (neo_)
and somebody told me the knock sensor has the same plug dont know if this is true or not is it??
Old Dec 9, 2006 | 05:45 AM
RTW DC2R's Avatar
IIRC the Knock sensor has a similar plug.
all you need to do is check the wire colors on the plugs to know where they go. either check a helms, the HT archives, or report back to us and we can tell you where each plug needs to go. its not rocket science.
Old Dec 9, 2006 | 06:26 AM
i hate all these abrevations whats IIRC now??
Old Dec 9, 2006 | 06:44 AM
RTW DC2R's Avatar
If I remember correctly...
Old Dec 9, 2006 | 06:47 AM
b19coupe's Avatar
IIRC AFAIK FTW ROFLMFAO-WTF?
Old Dec 9, 2006 | 08:49 AM
00MRSi's Avatar
Default Re: (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">IIRC AFAIK FTW ROFLMFAO-WTF?</TD></TR></TABLE>
nice.
Old Dec 9, 2006 | 09:11 AM
What the Hell's AFAIK again? I never got the memo for that one.
Old Dec 10, 2006 | 08:21 AM
neo_'s Avatar
Default Re: (GO-FIGHT-KILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">What the Hell's AFAIK again? I never got the memo for that one. </TD></TR></TABLE>
http://www.gaarde.org/acronyms/
92lxsleeper
16
Jun 12, 2009 06:38 AM
1337 Si
Oct 2, 2008 01:59 PM
94allmotor
24
Sep 8, 2007 08:08 PM
smokinsi
Jul 18, 2004 05:09 PM
