TPS sensor CEL code......
Old Jan 4, 2007 | 06:43 AM
kinkyintegra's Avatar
Default TPS sensor CEL code......
I just got a code 7 for my em1 which is the tps. I just got engine freshly rebuilt so its a new engine basically so i only have 15 miles on this rebuild. i was driving and the CEL popped up. the car doesnt drive any different, i made sure to check if it was plugged in right. My question is: How will this affect my car...will it eventually start driving bad or is there a fix to this? Should i try to replace it as soon as possible, so i guess i can buy a used one from someone.
Old Jan 7, 2007 | 11:14 PM
IntegraXTR's Avatar
your vtec might not engage...
try do a search on how to check the voltage going to the tps unit...
.4 idle, 4.5 wot etcetc
Old Jan 8, 2007 | 05:53 AM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
i have the same problem my tps broke and for sum reason my engine wont pass 2k rpms it just sits there and pops as if i had 2step o sumthing is this the problem??
Old Jan 8, 2007 | 07:09 AM
92ehatch's Avatar
Default Re: (99hondacura)
i had erratic idle when my tps was throwing a cel. when the cel was on it idled high all the time.
its really easy to adjust.
you need to loosen the screws on the back (might have to cut slits to loosen them)
then use a voltometer and attach the positive to the middle wire (red wire)
and the ground to a ground. Turn the tps until it reads .45v closed throttle and 4.55 wide open throttle.
Old Jan 8, 2007 | 07:44 AM
thanks cuz yea my car was revving hell of high!
Old Jan 8, 2007 | 11:43 AM
well i reset it and it hasnt came back...but i think i just spun a bearing in my freshly fully rebuilt b16 so idk anymore....and i wouldnt know if vtec engaged or not. i never go to take it that high...only had 150 miles on it.
Old Jan 8, 2007 | 01:16 PM
how do u know u spun a bearing
Old Jan 8, 2007 | 01:56 PM
i dont know....im guessing because i got it rebuilt because of a spun bearing and it made the same noise and all symptoms...same knocking.....ill prob know tomorrow
Rayog21
Aug 26, 2009 08:31 AM
MonKK
Jan 8, 2009 08:46 AM
dsadas89das78934
11
Aug 27, 2004 06:47 AM
