TPS problem need suggestions
Hello,
I have an H22A in an EG and my problem is that my CEL is on and the code is code 7 witch is tps. Or Throttle Position Sensor, so to start I had a dirty iac valve ( car would erratically idle from 2k down to 900 rpms) and figured my whole intake assembly could stand to be cleaned so i took off my throttle body and im plenium and iac valve and cleaned it alll with throttle body cleaner and elbow grease. when i put everything back together it then threw the tps code (there was no cel on before i took everything off) the car ilded better now but still high at around 1,100 rpms and thats the idler screw all the way tight. i cleaned the tps and all the areas it connects to with electrical cleaner and it still throws the code... At that point i replaced the sensor and reset the cars ecu and it still is throwing the code. My question is after i replaced the sensor what else could be broken or dirty to be throwing the tps code off still? Also why canbt my car idl any lower when i have stock intake set up aside of SRI?
Thank you in advance for your guys help.
Dane
Dane
Re: TPS problem need suggestions
try ajusting dizzy too my tps is bad as well but you can ease the idle with your dizzy since your idle screw is tight. i have replaced tps three times and still trow code so when you figure that out let me know.
ludacole
08-13-2005 11:59 PM
