Getting Head Off Block
Old Aug 8, 2005 | 05:33 PM
LSEGHATCH's Avatar
Default Getting Head Off Block
How can I remove my D15 head off of the block w/o using a pry bar? I've tried pulling on it and nothing. If I need a pry bar, where do I pry?
Old Aug 8, 2005 | 05:49 PM
NJIN BUILDR's Avatar
Default Re: Getting Head Off Block (LSEGHATCH)
Remove the bolts....and lift it off. No prybar required.
Old Aug 8, 2005 | 05:54 PM
LSEGHATCH's Avatar
Default Re: Getting Head Off Block (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Remove the bolts....and lift it off. No prybar required.</TD></TR></TABLE>
I know to remove all the hardware, wiring, etc.. it just doesn't wanna come off.
Old Aug 8, 2005 | 06:13 PM
Sometimes the dowels can be a little corroded and can stick a little.You don't want to pry between the head and the block.Try putting two head bolts back in about three or four treads and tap the head with a soft (plastic) hammer on the end of the head.The bolts will keep it from flying off when it breaks free.Take one more look to make sure all the bolts are out.
Glenn
Old Aug 8, 2005 | 06:31 PM
LSEGHATCH's Avatar
All 10 bolts are out and the tapping does nothing........damnit another bump in the road.......
Old Aug 8, 2005 | 06:56 PM
Jay Blazed's Avatar
try side to side GENTLY!!!
Old Aug 8, 2005 | 06:57 PM
LSEGHATCH's Avatar
Default Re: (Jay Blazed)
What should I be grabbing onto to get a firm grip. This thing will not budge!
Old Aug 8, 2005 | 07:09 PM
TurboCoop's Avatar
Default Re: (LSEGHATCH)
pry it with something between the block and the water neck, im sure there is places to pry where you wont scratch up the deck surface.
Old Aug 8, 2005 | 07:16 PM
LSEGHATCH's Avatar
Default Re: (TurboCoop)
Waterneck being the neck where the hose from the top of the radiator goes?
Old Aug 8, 2005 | 07:25 PM
Jay Blazed's Avatar
I forsee trouble
i say chill before you do some damage
Old Aug 8, 2005 | 07:32 PM
LSEGHATCH's Avatar
Well I haven't done anything yet, except for try pulling it off and tapping it. Prying is next but I don't know any safe spots to do so.
Old Aug 8, 2005 | 07:34 PM
Jay Blazed's Avatar
exactly
Old Aug 8, 2005 | 07:36 PM
LSEGHATCH's Avatar
So anyone know a safe way to pry a head off?
Old Aug 9, 2005 | 07:16 AM
LSEGHATCH's Avatar
Old Aug 9, 2005 | 09:14 AM
postalrat's Avatar
id try getting a big rubber hammer and beating it off. i guess its possible you either have some sort of corrosion or maybe some sort of adhesive holding that thing on. if it still refuses to budge after 40 or so good whacks your on your own.
of course something bad can happen doing this but at least its not a terribly expensive engine.
Old Aug 9, 2005 | 09:42 AM
LSEGHATCH's Avatar
Default Re: (postalrat)
I don't understand why it's being such a PITA. Everything is removed from what I've read and been told. The fact that it has 175,XXX on the original gasket could probably be a good factor but still. Would anyone reccomend using a dead blow hammer (plastic with sand inside the head) because all the rubber mallet does is bounce off.
I would like prying to be a last resort!
Old Aug 9, 2005 | 10:34 AM
postalrat's Avatar
never tried it but maybe if you turned it over a few times with the starter it might pop off. drop some of the bolts down in their holes like someone suggested so the head doesnt slide right off and turn it over a few times. its possible the compression will be enough to break it loose.
cams in would probably be best so you get only compression and not a powerful vacuum in other cylinders. at the least i would remove the spark plug from 2 and 3 or 1 and 4 if you dont have your cams in.
would be an interesting experiment either way and probably a less harsh then a pry bar
Modified by postalrat at 12:10 PM 8/9/2005
Old Aug 9, 2005 | 02:34 PM
LSEGHATCH's Avatar
UP
Old Aug 14, 2005 | 08:47 AM
LSEGHATCH's Avatar
up
Old Aug 14, 2005 | 09:02 AM
W O T's Avatar
man, get a rubber mallet and just start smacking the **** form all sides for 5 min, mine came off easily but for a friends z6 we had to smack it a bit to get the dowels a little loose
DO NOT PRY IT
You will most likely scratch the **** out of the block if you can even get a place to pry from
I would never resort to that, get a friend if you have one ot try and lift and shake the **** back and forth while you are hitting it with the hammer
will work
4g4dcruisin
10
Sep 26, 2012 09:30 AM
JdM_RACeR07
Oct 19, 2006 12:43 PM
wood 1
13
Jun 4, 2006 09:01 PM
SPEED123
Nov 29, 2003 12:49 PM
Gonzo_SiR
Nov 3, 2003 11:35 AM
