Removing Stuck Head Stud???
Old Oct 29, 2007 | 06:29 AM
B18C_EJ8's Avatar
Default Removing Stuck Head Stud???
How does one remove a stuck head stud? I'm swapping blocks, and when I pulled the head yesterday, one stud is stuck in the block..
I tried wrapping a towel around the middle of the stud and turning it with a pair of channel locks, but it won't budge...
Suggestions?
Old Oct 29, 2007 | 07:43 AM
B18C_EJ8's Avatar
I forgot to mention that these are ARP studs, without the allen key hole in the top..
Old Oct 29, 2007 | 09:01 AM
all-mtr-teg's Avatar
Default Re: (B18C_EJ8)
is the allen key hole stripped?
Old Oct 29, 2007 | 09:08 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">these are ARP studs, without the allen key hole in the top.. </TD></TR></TABLE>
Old Oct 29, 2007 | 10:01 AM
hatchling37's Avatar
^ That **** makes me laugh. What you should do is thread on two nuts and jamb them together. Then merely put your box end on the nut closer to the head and hit the wrench to turn it. Don't try to reef on it to get it to turn, hitting it will give you more of an impact on the fastener and increase the chance of it busting loose.
Old Oct 29, 2007 | 10:24 AM
B18C_EJ8's Avatar
Dude, that's an awesome idea.. Will try that when I get home.
Old Oct 29, 2007 | 04:33 PM
B18C_EJ8's Avatar
Worked like a friggin charm... I have no idea why that one stud was so damn tight and the other 9 were loose as a goose...
killacam661
Feb 11, 2010 08:28 AM
GSR_hatch936
May 27, 2008 06:09 PM
skiracer8148
11
Aug 14, 2007 07:59 PM
civicb18Tkid
May 3, 2007 07:30 AM
D
Jan 8, 2004 04:01 PM
