shiftlite
Old Dec 16, 2008 | 12:21 AM
masijdm's Avatar
Default shiftlite
hey, i have a shift i want to wire it into gauge straight i looked at teamintegra one couldnt figure it out i need some help that shows it step by step exactly here is the picture of the one i bought
and the wire looks like this
Old Dec 16, 2008 | 12:36 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
http://www.youtube.com/watch?v=IY_rLch-ggA
Old Dec 16, 2008 | 12:41 AM
masijdm's Avatar
thats rpm gauge, i got a shiftlite mayne
Old Dec 16, 2008 | 10:07 PM
masijdm's Avatar
help :{
Old Dec 16, 2008 | 10:19 PM
CARMA_626's Avatar
Actually, you have a tachometer.
See those little pills? 7.7, 6.4, etc? Thats your rpm trigger. So essentially it's a simple tachometer with a big shift light.
So you need to wire it the same way you would wire a tach. Insert the rpm pill and that is when your light will trigger.
Now if you have a straight shift light...just the light...then it will not work with a stock tach. You need the one with the pills so it knows with to activate.
Old Dec 16, 2008 | 10:38 PM
masijdm's Avatar
but the problem is i didnt get those yellow tabs :/ only the shiftlite with just a wire lol from modacar
Old Dec 16, 2008 | 11:58 PM
hondamn1320's Avatar
So.. It only has 2 wires coming out of the light? If it does, then you bought the wrong light, as you would also need the tachometer to plug the light in. I think the light you were looking for is the "ProLite" shift light.
If the shift light has 3 wires coming out, red(power), black(ground), and green(rpm signal), then you would wire it the same way as the video showed you minus the white wire.
Hope this helped.
Old Dec 17, 2008 | 08:36 AM
CARMA_626's Avatar
Yeah, you bought the wrong light. That thing will only work with a tach with a shift light input.
Old Dec 17, 2008 | 12:04 PM
masijdm's Avatar
aight dang $60 went on water lol
civic-one
Mar 11, 2013 04:28 PM
SiZ
Apr 11, 2003 02:32 PM
xXx Justin xXx
Mar 12, 2003 11:22 PM
Aaron M
Oct 14, 2002 09:46 PM
