Autometer Shift Light Ques.
Old Jun 9, 2003 | 12:37 AM
99silverbullet's Avatar
Default Autometer Shift Light Ques.
I have the autometer shift light with the little pills and if I put in, for example a 6.6 rpm pill in, the shift light comes on around 7k so it is off by a few hundred rpms. I have it tapped in behind the cluster, would it be more accurate if I tapped it in the blue wire by the master cylinder? I've heard that the autometer tachs and shift lights are usually off by a few hundred rpms, anybody else have this problem? how did you fix it? TIA
Old Jun 9, 2003 | 02:42 AM
10K2HVN's Avatar
Default Re: Autometer Shift Light Ques. (99silverbullet)
well thats sucks if its unaccurate!
..but ive heard the stock tachs are also inaccurate...
good luck, heres a bump.
Old Jun 9, 2003 | 04:17 PM
Default Re: Autometer Shift Light Ques. (10K2HVN)
thanks for the bump, ttt again. anybody else?
Old Jun 9, 2003 | 07:01 PM
CNSK's Avatar
when my car idles, its not accurate to the autometer, but when i drive off, it seems to run at the same rpm.
Old Jun 9, 2003 | 07:03 PM
J337_UNIT's Avatar
Default Re: Autometer Shift Light Ques. (DrMartin)
i tapped mine into the ignition coil..i would say my aftermarket tach is more accurate
Old Jun 9, 2003 | 07:34 PM
Default Re: Autometer Shift Light Ques. (J337_UNIT)
I just tapped into the blue wire by the master cylinder and it seems accurate now. thanks fellas.
Old Jun 9, 2003 | 08:29 PM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99silverbullet &raquo;</TD></TR><TR><TD CLASS="quote">I just tapped into the blue wire by the master cylinder and it seems accurate now. thanks fellas.</TD></TR></TABLE>
that's the wire you are supposed to tap into
I just got my pills today. The shiftlight I bought from a user here only had a 6K pill got my 8400 pill in today.
tyler100
11
Dec 26, 2007 06:33 PM
ATS*Mark
Jun 27, 2007 12:47 PM
Georgethefierce
Jan 31, 2003 12:15 PM
civicmark
Jul 5, 2002 03:06 PM
crxaddikt
14
Apr 12, 2002 01:42 PM
