oil change
Old 08-22-2005, 07:05 PM
Jordans95si's Avatar
Default oil change
sorry guys for the absolutely noob question, but im only 16, i've helped my dad change oil and crap, and im tryin to learn this car crap, i figured i'd just change my own oil, can you guys just give me a quick run through of what do to, and ya'll would suggest changin my own oil right? no way to really mess it up?
Old 08-22-2005, 07:30 PM
flashmang's Avatar
Default Re: oil change (Jordans95si)
lol ... there are lots of ways to mess it up ... and crap haha
but seriously, you should be able to figure it out... there are a lot little tutorials on the web showing how to change your oil ... just google it !
good luck
Old 08-22-2005, 08:06 PM
typeS's Avatar
Default Re: oil change (flashmang)
remove oil filler cap
jack it up from the front
remove oil pan drain bolt
remove oil filter
replace oil filter with new honda filter
replace oil drain pan washer (with new honda washer) and bolt
fill oil, probably 4.5 quarts for your SI
lower car on level ground
put oil filler cap on again
check oil level
run motor for two minutes
check oil level
you want to use a good oil too. i reccommend mobil or mobil 1
_____________________-
don't ream me if i left anything out guys, i'm trying to help the kid. just correct or add on if necessary.
Old 08-22-2005, 09:59 PM
Too_Funny's Avatar
Default Re: oil change (typeS)
^^^I might add. Check the old oil filter for the o-ring. Sometimes that get stuck on the engine. Also, lube the o-ring on the new filter with some new oil.
Old 08-22-2005, 10:03 PM
I <3 Rotas
bby6's Avatar
Default Re: oil change (Too_Funny)
First things first
be careful, oil is hot after you've been driving your car.
Old 08-23-2005, 03:53 AM
zoopsta's Avatar
Default Re: oil change (girLuder)
another thing:
dont go under your car if its up on jacks, not safe man..
get a set of jack stands
Old 08-23-2005, 06:45 AM
integra15's Avatar
Default Re: oil change (zoopsta)
Yea dont just jack it up with a regular jack. Use jack stands or get some ramps and wheel chocks.
Old 08-23-2005, 07:55 AM
Lewdin' Incognito's Avatar
Default Re: oil change (integra15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra15 &raquo;</TD></TR><TR><TD CLASS="quote">Yea dont just jack it up with a regular jack. Use jack stands or get some ramps and wheel chocks.</TD></TR></TABLE>
Yes, our cars are too low to be messing around without stands!
You can buy the Honda filter from the dealership and it comes with the new crush washer, just in case you were wondering. I'm lazy (and without my own garage while in the apt) so I just buy the filters from the dealership 3 or 4 at a time and have the oil changed at a quick-change place.
Old 08-23-2005, 08:19 AM
Default Re: oil change (Lewdin' Incognito)
ok thanks for the help, i've been having some oil leaking from the oil filter i think it might be the o ring on it or something, so i'll try to get to the bottom of it all then
Hondas4All
10-22-2009 12:06 PM
jimmy193
08-17-2008 02:29 AM
bopbop93030
05-13-2008 04:30 PM
tilhasbb
17
08-13-2007 08:17 AM
civicboy95
52
02-13-2003 11:41 PM
Quick Reply: oil change
