nitrous help
Old Nov 1, 2001 | 07:39 PM
91lude's Avatar
Default nitrous help
What do u guys think of running the zex system on 91 prelude 2.1. i have intake hearder exhaust cam gears new clutch and timing belt. i wanna run like a 55 shot should i do it or will the car blow up ohh yea i have 93000 miles i need some good advice
Old Nov 1, 2001 | 07:44 PM
BoM's Avatar
BoM
Default Re: nitrous help (91lude)
i think you can do it, not that bad, i've seen some people run nos on 100k miled cars.
if ur car is in good shape do it 55shot that is
get a minor tuneup - ignition - plugs, rotor, cap, wires
plugs should be a step or 2 colder though
Old Nov 1, 2001 | 08:01 PM
91lude's Avatar
Default Re: nitrous help (bommiE)
i wanna do this **** bad as hell but i heard some horrer stories with nitrous
Old Nov 2, 2001 | 06:30 AM
LudeBehavior's Avatar
New User
If your car is taken care of you won't have to worry toomuch about it with a 55shot. Plus the zex does all the mixing for you threw their lil box. They just worry about high milage because there is a higher chance to burn your oil rings with higher mileage cars. I say go for it. I have 82k miles on my h22a1 and I am installing mine soon.
Old Nov 2, 2001 | 06:34 AM
laughinxxx's Avatar
New User
Default Re: nitrous help (LudeBehavior)
For just a 55 shot you don't have to do much. First get a compression check and a leakdown test. These will tell you if your engine is in good shape. Second, buy the Zex kit and install it. Thirdly, get NGK copper plugs and make sure that they are one step colder than stock. Only use 92 octane gas. Have fun. Doing a tune up is a good idea also.
Old Nov 2, 2001 | 08:00 AM
91lude's Avatar
Default Re: nitrous help (laughin2.2)
YEA I DID A TUNE UP ALREADY THATS WHAT I HAVE TO DO A COMPRESSION TEST
Old Nov 3, 2001 | 10:18 AM
GSRacer's Avatar
New User
shoot it shoot it!!!!!!!!
Old Nov 3, 2001 | 01:53 PM
laughinxxx's Avatar
New User
Default Re: nitrous help (GSRacer)
Do a compression test and and a leak down test. A shop can do the leak down for you.
4thgenlude
May 11, 2004 12:56 PM
f22suzuka
Jul 27, 2003 09:59 AM
Cone
Apr 19, 2002 05:11 PM
91lude
Nov 6, 2001 06:01 PM
91lude
Nov 1, 2001 09:24 PM
