wastegate to compressor vacuum line
Old Mar 25, 2004 | 01:42 AM
pissedoffsol's Avatar
25 Year Member
Default wastegate to compressor vacuum line
it says the side fitting on the gwastegate goes to the compressor side of the turbo. The top fitting goes to the boost controller...
my turbo (F-R t3/t67) has no vac lines hookup on the compressor that i can see... am i blind (doubtful), or am i doing this all wrong (likely)?
Old Mar 25, 2004 | 04:56 AM
kell211's Avatar
Default Re: wastegate to compressor vacuum line (pissedoffsol)
that's exactly how mine's hooked up. if yours doesn't have a fitting on the compressor side of the turbo (mines just an inch or so up from where the first charge pipe connects. you may have to tap one. but i'd wait for someone's opinion that knows for sure. so i here's a free bump for ya.
Old Mar 25, 2004 | 06:32 AM
99B16Si's Avatar
run it to the manifold instead, i and most other people like it better that way anyway...its a more accurate reading that the turbo because it makes the wastegate react off what the motor is actually seeing and not off the turbo before the pressure drop in the intercooler
Old Mar 25, 2004 | 06:44 AM
Rory Breaker's Avatar
Default Re: (99B16Si)
I have the nipple on my compressor capped and run my WG post-IC.
Old Mar 25, 2004 | 11:42 AM
25 Year Member
Default Re: (newgsrdriver)
so, just plugging it into my GE vacuum manifold is all i have to do?
Old Mar 25, 2004 | 12:08 PM
dfoxengr's Avatar
Default Re: (pissedoffsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">so, just plugging it into my GE vacuum manifold is all i have to do?</TD></TR></TABLE>
correct
Old Mar 25, 2004 | 12:41 PM
Nextelbuddy's Avatar
Default Re: (hybridvteceg)
i hate to thread jack but i have a question as well..
which hole on the top of the delta gate wastegate do i use with a EBC?
Old Mar 25, 2004 | 01:27 PM
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">correct </TD></TR></TABLE>
g0od enough
Old Mar 25, 2004 | 01:47 PM
Default Re: (nextelbuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">i hate to thread jack but i have a question as well..
bump
Old Mar 25, 2004 | 01:51 PM
Mad Cow's Avatar
The open one.
Old Mar 25, 2004 | 01:57 PM
Default Re: (MadCow)
thank you
Old Mar 26, 2004 | 04:42 PM
fullboostin's Avatar
anyone have a diagram for a tial 38mm wastegate? Only two holes on that one. Does the side go to boost controller and top goes to turbo?
Old Mar 26, 2004 | 05:05 PM
Default Re: (fullboostin)
if you are using a manula boost controller i beleive the side one goes to the comnpressor or manifold whichever you choose and teh manual boost controller goes inbetwen the 2 INLINE if you say.. but if you are using a electronic boost controller the COM side of the boost solonoid goes to the top vac port on the wastegate and the ND side of the solonoid gets Teed into teh vacuum line that goes from the compressor to teh side port on the wastegate.. hope that helps
Old Mar 26, 2004 | 07:01 PM
so when installing the only one that matters is the side which will go to my compressor.. correct? And i can leave the top one open?
Old Mar 26, 2004 | 07:04 PM
Charles B.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fullboostin &raquo;</TD></TR><TR><TD CLASS="quote">so when installing the only one that matters is the side which will go to my compressor.. correct? And i can leave the top one open?</TD></TR></TABLE>
leave the top one open if you have no boost controller. for the side one i would source the vacuum from the intake manifold. hth.
b18_integra
Feb 18, 2008 04:42 PM
HamiltonRex
Jan 2, 2006 12:12 PM
SpoolnByYou
Dec 2, 2005 11:14 PM
Ty.
Feb 3, 2004 04:15 AM
TurbothisLS
Sep 30, 2003 07:31 AM
