detonation with nitrous?
Old Oct 23, 2002 | 07:35 PM
lsteggy's Avatar
Default detonation with nitrous?
when you are running nitrous is it possible to detonate? i was told by someone that if you run nitrous it wont detonate because it is so cold. also i am planning upping the compression on my ls and run a bottle and someone sad that i would detonate becuase of the compression. i was just wondering if there is any truth to that?
Old Oct 23, 2002 | 07:36 PM
WONG FRIED RICE's Avatar
Default Re: detonation with nitrous? (lsteggy)
no..u can detonate.
Old Oct 23, 2002 | 07:55 PM
ion_four's Avatar
Default Re: detonation with nitrous? (JDMB16ACRX)
how do you think people crack the welds on their manifolds?
does anyone know how to calculate/approximate effective compression on a N2O motor?
::edit:: you'd need to figure out what the effective compression is to figure out how likely you'd be to detonate on pump gas (or whatever you're running)
for forced induction effective compression = ((boost/14.7)+1) * static compression...so, you might be able to fudge it by saying effective compression (((nitrous shot/10)/14.7) +1) * static compression, assuming 1lb of boost = an additional 10hp... this could be completely wrong, but ya know
[Modified by ion_four, 4:59 AM 10/24/2002]
Old Oct 25, 2002 | 04:19 PM
lsteggy's Avatar
Default Re: detonation with nitrous? (ion_four)
how does nitrous detonate when its so cold???? isnt detonation caused by heat? and preignition
Old Nov 4, 2002 | 02:50 PM
lsteggy's Avatar
help im an idiot
Old Nov 5, 2002 | 05:27 PM
IMALLSLO's Avatar
A car will detonate on nitrous.
If the car is detonating do this
1. turn back the timing
2. turn up the fuel pressure,higher octane
3. run a colder plug
4. either put a bigger fuel get or lower the nitrous get
Old Nov 5, 2002 | 10:41 PM
gtcali's Avatar
Default Re: detonation with nitrous? (proclassracer)
When I first put in my nitrous, I used stock spark plugs, with stock timing and boned out up a hill. I had some detonation. I pulled out my spark plugs, and one was shattered.
[Modified by gtcali, 7:42 AM 11/6/2002]
Old Nov 5, 2002 | 11:36 PM
Modify's Avatar
Default Re: detonation with nitrous? (gtcali)
the secret
plug 2 number colder
race gaz 100 octane
timing retard 2 degres
for the fuel pressure depends if its a wet or dry kit
Old Nov 5, 2002 | 11:43 PM
PrecisionH23a's Avatar
help im an idiot
Just because you admit it......
Detonation- because a nitrous injected engine burns so much faster and hotter than an air/fuel charge it will go into detonation at the same timing than would be perfect for just gasoline and air. So on nitrous motors, a timing retard from 2-12 degrees total advance is needed. Nitrous detonation is much more severe than the normal "ping." It's shockwaves have the capacity to bend rods and crack piston tops. Another thing is that most people don't know what they're hearing. Nitrous detonation sounds more like the distant rumbling of thunder than elves with little hammers banging around under the hood. The bummer about a nitrous motor is the fact that it needs two timing curves. One normal and one about, for a 50hp shot for a fiero, 2-3 degrees retarded. So under normal conditions it makes the car sluggish and causes decreased fuel economy.
Thank you for your honesty.
Old Nov 6, 2002 | 06:27 AM
TypeC's Avatar
Default Re: detonation with nitrous? (GudeH23a)
help im an idiot
Laughing my *** off!
Old Nov 6, 2002 | 09:40 AM
gtcali's Avatar
When people say retard 2-3 degrees. (maybe I didn't understand your post)
That means 2-3 degrees retarded from stock timing right? That's what I've always done. So like 14degreees BTDC right?
[Modified by gtcali, 6:40 PM 11/6/2002]
mcln594
Nov 11, 2007 08:52 PM
ls-v*2
Feb 28, 2007 02:52 PM
boosted k20
Jul 26, 2005 07:46 PM
turbohf
Apr 13, 2003 11:51 AM
S13 slide
Jan 9, 2002 06:34 PM
