hodata s200
Re: hodata s200 (preludepower01)
a p28 p72 there is another one but cant remember the code, and an OBD-II to OBD-I jumper. then a tuner to make it run right.
http://www.hondata.com ?
It would also help if you told us what you were putting it in and what you were using it on...
You will need a OBD1 ECU and a Converter Harness from OBD2 --> OBD1 if you're using your stock wiring.. Which I assume you are..
What you would need a Jumper for?? Unless you're trying to get something to work that doesn't normally work on certain ECU's...
Re: (carnot)
Emissions won't warrant a hondata EMS. You will need the obd2 computer in your car to pass emissions.
All you have to do is just swap the ecu out when you have to get your car tested.
If you need any info on hondata units PM me
