obd2 to obd1 ?
Old Jan 12, 2006 | 06:13 PM
97turboteg's Avatar
Default obd2 to obd1 ?
pretty soon im going to put my turbo kit on...im going to get hondata, and im going to need to change my ob2 to obd1. i dont know what to do, or how to do it. also how much will this process cost me? i pretty much need all the info on doing this and the cost. what will i need to buy? anyones .2cents are welcome here@!
-god made turbo lag, so the v8's could catch up!
Old Jan 12, 2006 | 07:17 PM
tig3rxiong's Avatar
obd2 to obd1 harness
obd1 ecu<-------junkyard
Old Jan 12, 2006 | 08:18 PM
iH8RICERZ's Avatar
Default Re: obd2 to obd1 ? (97turboteg)
Depending on which car/motor you have will depend on what you should get. Lets assume you have a 1997 GSR. If thats the case, you need the following:
obd2A-1 conversion harness: cost $50-120 (average $80)
obd 1 p72/p28/p08/p30/p13, converted to vtec p05/p06 ecu's (if you buy it stock, expect to pay anywhere from $20-$200 depending on which ecu you want to use...)
If your going hondata, then typically, people go with a obd 1 p28 ecu. When you buy everything from hondata, they will send you everything that needs to get soldered into the ecu.
Total average cost= $200 to $350 (not including hondata)
hope that helps.
Old Jan 12, 2006 | 08:50 PM
97turboteg's Avatar
Default Re: obd2 to obd1 ? (iH8RICERZ)
well i got the b18b1. so no worries about all the vtec stuff. hope that makes it easier, and cheaper for myself...how about now?
Old Jan 12, 2006 | 10:25 PM
im done's Avatar
just get the obd2 to obd1 conversion harness and a obd1 ecu. if you get the harness make sure its the one for your car. i have obd2a to obd1 conversion harness for sale if you need it
Old Jan 12, 2006 | 10:41 PM
iH8RICERZ's Avatar
Default Re: obd2 to obd1 ? (imc2pid)
96-98 civics/96-99 integras are obd2 version A
99-00 civics/00-01 integras are obd2 version B
If your car is a 97, then you'll need the obd2A-1 conversion harness.
As for having a b18b1, start looking for the obd1 pr4 (came from 92-93 LS/RS/GS) or the obd1 p75, or was it p74! LOL..cant remember, i think its p75...came from 94-95 LS/RS/GS. OR, you can run a p06 or p05 ecu. Call hondata and make sure
Old Jan 13, 2006 | 05:53 AM
97turboteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imc2pid &raquo;</TD></TR><TR><TD CLASS="quote">just get the obd2 to obd1 conversion harness and a obd1 ecu. if you get the harness make sure its the one for your car. i have obd2a to obd1 conversion harness for sale if you need it</TD></TR></TABLE> you got the right one? what you asking?
mitchell_2kSiR
Dec 30, 2007 09:32 AM
JmurGSR98
Sep 22, 2005 04:35 PM
DC2 B18C TSL
Nov 11, 2003 11:33 PM
shawnc21
Jan 9, 2003 11:21 AM
Type RS
Nov 18, 2002 10:09 PM
