h22 missing not sure why
car is breaking down at any rpm higher than 7500.
We have put a new msd boxs coil and ignitor on made no differance. car is burning fuel very clean almost to the point it is lean so i am wondering if my fuel cell is to small for the pump and it is sucking the pump and and straving it of fuel.
the motor is a built h22 13.0 to 1 compression, port flow head itbs. the only thing i changed from last year was the bigger fuel pump.
please feel free to ask any question that might u might need to help me figure the problem out.
had it on the dyno and graph are fine till arund 7 to 7500
Well its really going to have to be fuel or ignition. .
If the A/F is fine even when it begins to break up i would go over everything in the ignition system.
Cap, rotor, wires, etc
What type of plugs are you using?
using aem ecu, msd digital 6 box and a blaster 2 coil. am going to switch to the aem coil packs this winter.
i will try and close the gap to .15.
