compression test
Old Mar 11, 2004 | 05:10 AM
ITR77's Avatar
Default compression test
Honda dealership did compression test my 2001 ITR and all four cylinder had 195 psi. Is this good or bad. thanks
Old Mar 11, 2004 | 06:33 AM
thk's Avatar
thk
Members Only
Default Re: compression test (01ITR0716)
if it's straight across, it's fine.
compression tools are not all equal. some read higher and some read lower.
Old Mar 11, 2004 | 07:03 AM
bus stop's Avatar
Default Re: compression test (thk)
what he said
Old Mar 11, 2004 | 07:08 AM
Bbasso's Avatar
https://honda-tech.com/zerothread?id=793978
Just out of curiosity... Why didn't you take the Ideas/ comments posted here and apply them to your question?
Old Mar 11, 2004 | 07:14 AM
itr 00 0108's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">if it's straight across, it's fine.
compression tools are not all equal. some read higher and some read lower.</TD></TR></TABLE>
I gotta disagree...I wouldn't touch a car that new with compression that low.
Old Mar 11, 2004 | 07:40 AM
thk's Avatar
thk
Members Only
Default Re: compression test (itr 00 0108)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr 00 0108 &raquo;</TD></TR><TR><TD CLASS="quote">I gotta disagree...I wouldn't touch a car that new with compression that low.</TD></TR></TABLE>
Disagree all you want. Unless it's some atrocious number like low 150s, it's all relative.
I mean, my compression scores were in the 245s. That's definitely out of the norm too but it can be attributed to the tool.
Old Mar 11, 2004 | 07:47 AM
I mean, my compression scores were in the 245s. That's definitely out of the norm too but it can be attributed to the tool. </TD></TR></TABLE>
Yours are higher...which is fine...his are lower, which isn't good IMO...anything below 200 for a Type R is getting down there.
Obviously we have different standards.
Old Mar 11, 2004 | 07:48 AM
.RJ's Avatar
.RJ
How do you know the gauges are calibrated properly?
If there's a concern, do a leakdown test.
Old Mar 11, 2004 | 07:51 AM
bus stop's Avatar
the best way to test it is using a different compression gauges.
Old Mar 11, 2004 | 07:57 AM
Default Re: compression test (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
If there's a concern, do a leakdown test.</TD></TR></TABLE>
I don't...so whats your point? I could ask that about every compression test...all I know is the range that the car should be in, and 195 is below that range.
Why am I being attacked for my personal preferences? Get real.
Old Mar 11, 2004 | 08:00 AM
Chris N's Avatar
Why am I being attacked for my personal preferences? Get real.</TD></TR></TABLE>
THAT low?? lol, its WITHIN spec.
Racebrewer's Avatar
I'd first find out if they did the test properly
1) Warm engine
2) Open throttle
John
Old Mar 11, 2004 | 08:03 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr 00 0108 &raquo;</TD></TR><TR><TD CLASS="quote">I don't...so whats your point? I could ask that about every compression test...all I know is the range that the car should be in, and 195 is below that range.</TD></TR></TABLE>
And what does the helms say about compression test spec?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Why am I being attacked for my personal preferences?</TD></TR></TABLE>
Because your "personal preferences" are absolute horseshit and have no rhyme, reason or tech to back them up with.
Old Mar 11, 2004 | 08:05 AM
Chris N's Avatar
It says 195 is within spec.
Old Mar 11, 2004 | 08:09 AM
.RJ's Avatar
.RJ
Default Re: compression test (Chris N)
Minimum of 135, Nominal 199, Maximum Variance 28.
Page 3-2 of the 98-01 Integra Helms Manual.
Old Mar 11, 2004 | 08:29 AM
mstewar's Avatar
Because your "personal preferences" are absolute horseshit and have no rhyme, reason or tech to back them up with.</TD></TR></TABLE>
agreed.. personal preferences do not necessarily equal what the service manual says..
Old Mar 11, 2004 | 09:15 AM
Bbasso's Avatar
For all those people including I who get 200+ equally how does that work... are we doing something wrong when the range is lower?
Old Mar 11, 2004 | 09:20 AM
.RJ's Avatar
.RJ
Default Re: compression test (Bbasso)
That is the "Nominal" value.
There is not a "Maximum" listed in the service manual.
Nominal = normal
Minimum = your ***** gonna blow up soon
Old Mar 11, 2004 | 09:24 AM
FourDoorTypeR's Avatar
Anything above 130 Honda defines as "nominal". Also, Honda says there shouldn't be a variance greater than 28 points between each of the cylinders.
Just to give you something to compare to, my 94 GSR motor with 99k miles had 195 comp across the board and ran a 15.0 completely stock so that's not a terrible number.
My R motor with 20k miles tested 240 240 240 243
Old Mar 11, 2004 | 09:28 AM
Bbasso's Avatar
ok, thanks
Old Mar 11, 2004 | 10:15 AM
Dude, you are absolute ***....case closed...it's people like you that make this board suck compared to others....people like you have such a elitist attitude and no reason for it.
There are ways to be tactful when people are wrong...you chose to be rude...great guy!
Old Mar 11, 2004 | 10:19 AM
Chris N's Avatar
There are ways to be tactful when people are wrong...you chose to be rude...great guy!</TD></TR></TABLE>
Shall I go dig up your posts? You don't help this board at all.
Elitist?? LOL, look in the mirror.
Old Mar 11, 2004 | 10:25 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr 00 0108 &raquo;</TD></TR><TR><TD CLASS="quote">There are ways to be tactful when people are wrong...you chose to be rude...great guy!</TD></TR></TABLE>
You were called out on being wrong and attributed it to personal preference. I did not attack you. I asked a question and proposed an additional test.
You continually post information as fact when it is wrong. And most of your posts have a very abrasive/negative attitude. Its really gotten old.
mstewar's Avatar
you spout incorrect knowledge as fact and then challenge people when they tell you you are incorrect.. you expect that they're going to be nice? not here, buddy..
Old Mar 11, 2004 | 11:01 AM
Its_real&its_spectacular's Avatar
New User
Wow did this ever get ugly. Anyway, to get back on topic, a general rule that can be applied is that as long as the numbers are all within 10%, then they're just fine.
joey1320
Honda S2000
Feb 19, 2008 05:33 PM
duneracer69
Jul 27, 2007 04:08 AM
dbiker207
Nov 26, 2006 07:10 AM
snowblind7x
Apr 13, 2005 08:12 PM
DOHCarp
Sep 11, 2003 07:10 PM
