Flywheel resurface?!?!
Yo guys,
I'm changing my clutch tomarrow, and was wondering what you guys think about resurfacing the flywheel. My friend says not to bother, since I'm just changing it to an Exedy standard clutch...not a racing clutch or anything. Time is also an issue; and I've also heard it isn't the cheapest thing to do..anywho..thanx.
if it needs it i would, hard to explain but you can tell weather you can pass on it or not once you have it out. If it doesn't look friendly to griping your friction plate be safe and resurface.
Re: Flywheel resurface?!?! (Heinz57)
your suppose to resurface the flywheel everytime you change the clutch unless you don't mind premature clutch wear. cheaper resurfacing a flywheel then getting a all new clutch. just my .02
resurface it. the service is only around $25 dollars or so and if you don't resurface it, the flywheel will not wear evenly with the clutch which causes a possibilty for an improper break in of the clutch.
Re: Flywheel resurface?!?! (Hatch4urSnatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch4urSnatch »</TD></TR><TR><TD CLASS="quote">the service is only around $25 dollars </TD></TR></TABLE>
WTF!?
Every place in my area charges $50 because the flywheels are stepped and they have to pull the pins to resurface...
WTF!?
Solbros Owns Me
Re: Flywheel resurface?!?! (JV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV »</TD></TR><TR><TD CLASS="quote">
WTF!?
Every place in my area charges $50 because the flywheels are stepped and they have to pull the pins to resurface...</TD></TR></TABLE>
hmmm...some cheap machine shop near me did mine in 20 minutes for 30 bucks....best flywheel job I've seen in awhile also
It's like resurfacing the rotors when you change brakes....just do it, don't be cheap
WTF!?
Re: Flywheel resurface?!?! (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
It's like resurfacing the rotors when you change brakes....just do it, don't be cheap</TD></TR></TABLE>
I already did it but it still pisses me off that i'm paying more than all of you...lol
i think he was referring to me..i'm the cheap ***..or so it seems. I'm not cheap, yo! haha..I'm gonna go look into it..the first task is takin' the tranny out! Me and my friend never done it b4..thats why we're starting tomarrow (memorial day) morning at 8am..to whenever it gets done! hahaha..thanx fo' the support, yo's.
B_Swapped93
04-04-2013 06:30 PM
