MBC : Hook up?
Old May 5, 2005 | 07:34 AM
STL01Civic's Avatar
Default MBC : Hook up?
I got Hallman Manual Boost Controller. Their are 2 vaccum lines. One is hook up to the turbo and the other goes to__________????
I think it is to the charge pipe, not too sure. Anyone help me out.
If it is tap in the charge what kinda fitting would I need.
A pic would be great.
Thxs
Old May 5, 2005 | 08:08 AM
SOHC_MShue's Avatar
Default Re: MBC : Hook up? (STL01Civic)
One goes to a vacuum source ie: somewhere off of the intake manifold or your turbo compressor housing. The intake manifold will give you the best reading. The other vacuum line goes to your wastegate actuator(or side external wastegate port if you have one).
Old May 5, 2005 | 10:48 AM
STL01Civic's Avatar
Default Re: MBC : Hook up? (SOHC_MShue)
I did a search on the net. It said one to the turbo wastegate. the other to the mainfold and bov.
Has anybody hook up like that b4?
Old May 5, 2005 | 11:08 AM
SOHC_MShue's Avatar
No there is only one line that goes to the manifold. You only need one vacuum source.
Old May 8, 2005 | 02:39 PM
DualCamDan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STL01Civic &raquo;</TD></TR><TR><TD CLASS="quote">I did a search on the net. It said one to the turbo wastegate. the other to the mainfold and bov.
Has anybody hook up like that b4?</TD></TR></TABLE>
i think what he's asking is the on goes to the wastegate and the other gets a T in the line from the BOV-&gt;IM
is that correct?
19_HaTcH_92
Feb 20, 2010 03:24 PM
almostjdmeg
Mar 10, 2008 01:00 PM
2LiterTurboSeR
Apr 19, 2006 12:33 PM
StolenTeg
Jun 16, 2004 05:59 AM
kholmes
May 7, 2004 11:34 AM
