Idle Surging
Old Jan 9, 2014 | 02:50 PM
KidDxbOrI's Avatar
Default Idle Surging
93 civic idle is surging from 1000-2100 rpm , can anyone tell me why ? How to fix it , unplugged iacv idle was perfect
Old Jan 9, 2014 | 04:51 PM
goldsy's Avatar
Default Re: Idle Surging
Happening all the time? Only when the car is cold? Only when the car is warm?
Old Jan 10, 2014 | 06:09 PM
onemanwolfpack's Avatar
So I think you just answered your question... you said you unpluged the iacv and it idles perfect. Replace your iacv then. Haha. It can be a iacv, fast air idle or a vacuum leak that will cause surge.
Old Jan 10, 2014 | 06:20 PM
goldsy's Avatar
Or air in the cooling system.
Old Jan 11, 2014 | 12:43 AM
MisereNoire's Avatar
also an incorrectly set idle speed
Old Jan 12, 2014 | 07:41 AM
GhostAccord's Avatar
If you unplug your IACV and the idle levels out that usually indicates that you have a vacuum leak somewhere. It doesn't always mean that the IAC valve isn't working. That satually shows that it is opening and closing.
What have you done to your car recently? Have you done any work around the throttle body, intake manifold or vacuum lines?
Surging idle is most often caused by;
- Vacuum leak (hoses or gaskets leaking)
- FITV or idle out of adjustment
- Improper signal from ECT sensor (bad sensor or air bubble in cooling system).
- Dirty IAC valve or throttle body
- Throttle stop or throttle cable out of adjustment.
Old Jan 13, 2014 | 01:11 PM
arbii47's Avatar
I have the same idle surging problem on my 2000 Honda Accord EX. Does anyone have a picture showing the location of the Idle Air Control Valve? Is it located BELOW the throttle body?
Old Jan 13, 2014 | 01:26 PM
The 2000 Accord with a stock F23 does not use the IAC or FIT valves. It uses a Rotary Air Control Valve (RACV) it is basically the FITV and IACV combined into one. It is mounted to the backside of the intake manifold, between the firewall and intake manifold.
Old Jan 14, 2014 | 04:29 PM
VegasInvasion's Avatar
I'm Huge In Japan
https://honda-tech.com/forums/honda-prelude-4/end-all-idle-surge-bounce-etc-problems-thread-1979500/
try searching.
b20bFourDoorCivicLX
Honda CR-V & Element
Oct 10, 2013 06:35 PM
axis11
May 16, 2013 08:16 PM
Civic Racer X 7
Jul 23, 2003 07:19 AM
Pele
Feb 9, 2003 01:01 AM
