Dizzy problem..
Old Aug 31, 2005 | 11:28 AM
tgreaves's Avatar
Default Dizzy problem..
I am having a problem with my obd1 b-series dizzy.. Before getting into the problems with it I am using my friends dizzy and it works great so I know thats the problem..
It doesnt spark the plugs at all.. I changed out the coil and also changed out the ignitor.. The coil I switched it with might be bad but I know the ignitor is fine, its brand new..
Everyone once in a while it will fire the plug but not much.. I am using an AEM EMS so I can see that the other sensors in the dizzy are working fine and the EMS is turning on STAT SYNC(working the ignitor).. Any ideas here..
Old Aug 31, 2005 | 07:53 PM
slomofo's Avatar
GDD Member
Are the cap/rotor ****? You said you put a friend's distributor on your car and it ran fine, how bout taking his coil and trying it.
Old Sep 1, 2005 | 06:10 AM
tgreaves's Avatar
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Are the cap/rotor ****? You said you put a friend's distributor on your car and it ran fine, how bout taking his coil and trying it. </TD></TR></TABLE>
Im going to try and use his coil tonight..
theEFkid
Apr 9, 2012 05:43 PM
1badcrx
May 9, 2009 12:58 AM
Quade
Oct 27, 2004 11:29 AM
FitCRX
Feb 3, 2003 07:13 PM
gsrvx
Jun 6, 2002 11:27 AM
