ABS
Old Dec 18, 2003 | 10:49 AM
H22A EG6's Avatar
Default ABS
my buds teg GSR abs light comes on after like 2 min of driving. it works at first the dosent work any more. does an one know whats up with it???
any comments will healp thanks
Old Dec 18, 2003 | 10:53 AM
timmy8151's Avatar
Default Re: ABS (H22A EG6)
Pull the code from the service connector and get the error code. Once you get the code, you can diagnose the problem.
Old Dec 18, 2003 | 07:20 PM
darrinbrewer's Avatar
Default Re: ABS (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">Pull the code from the service connector and get the error code. Once you get the code, you can diagnose the problem.</TD></TR></TABLE>
yeah just instant message me the code and i'll tell you your problem...if you don't know the procedure to get the code:
put a peice of speaker wire into a 2 hole connector under the pass. side dash, near the ecu, mines tucked up under the glove box, after insertinf wire, turn key to "on" position, watch the abs light blink, they blink, then pause, then blink again, it may be a 2 part code, so count the blinks, wait for the pause, count again...and let me know..
Old Dec 18, 2003 | 07:23 PM
timmy8151's Avatar
Default Re: ABS (darrinbrewer)
Just to add to the above post. A long blink=10 while a short blink=1
Old Dec 18, 2003 | 10:26 PM
H22A EG6's Avatar
ok will do guys thanks
Old Dec 21, 2003 | 11:45 PM
H22A EG6's Avatar
i got a 8 and a 4 but these have nothing to do with the brakes
what could be the prob??
Old Dec 22, 2003 | 07:09 AM
JintegraLS95's Avatar
I also have problems with ABS...can someone send me the codes? gemeni84@hotpop.com
Old Dec 22, 2003 | 09:47 AM
the 8 and the 4, if thats your abs light blinking..it means faulty abs control unit, no other causes or fixes, just says faulty abs control unit, if it was a 4, then 8, it means left rear sensor, just look at pic below, i cut and pasted from my obd1 helms integra manual, what ecu are you running? could it be possible the ecu isn't capable of seeing the abs? i just see your name h22a eg6..just wondering about it..
Old Dec 22, 2003 | 01:21 PM
H22A EG6's Avatar
good ino you da man. it is in my friends GSR not my hatch
serjey15
Feb 6, 2011 08:11 PM
arren123
Jun 18, 2007 04:00 AM
b20acura
Jun 17, 2007 10:53 PM
aclw2
Apr 4, 2004 01:21 PM
