Honda Insight & CR-Z Hybrid Honda Insight and CR-Z Hybrid discussion forum.
CRZ OFFSETS
Old 02-19-2014, 06:35 PM
  #26
Johnny_9's Avatar
Default Re: CRZ OFFSETS
Originally Posted by 2x0
To answer the original question the stock wheels are +45 offset, in either a 6" wide standard or 6.5" wide optional oem wheel. The front wheels are flush at about 15-20mm lower offset than stock, and the rears at 30-35mm. If you want a flush look in back and no poke in front youll have to run spacers in the rear or a staggered setup, since the rears are much more sunk in.
Also if you lower the car on anything wider than stock wheels, you will probably need to run slightly stretched tires, negative camber and/or roll and shave the inside of the fenders. This car is not friendly for aggressive fitments, but it can be done.
Very Good Reply. Thanks!
Old 11-09-2015, 05:22 AM
  #27
CHIBA280's Avatar
Damn I wish I can do that to my 13 CR-Z ,. I just would not know how to..I would have to take it to someone who does...lol..will check around, I have the same white one..you guys did a fantastic job on your cars, thanks for sharing.
mynameizstitch
06-04-2012 04:04 PM
2LEM1
03-26-2012 09:47 AM
revolt_allmotor
Suspension & Brakes
11-06-2005 09:04 PM
sleepyEK
11-25-2003 09:27 AM
Kid1320
23
02-12-2003 10:01 PM
Quick Reply: CRZ OFFSETS
