CRZ OFFSETS
What are the average offset on the crz around here? I'm into the hellaflush scene because obviously i bought this car to save gas so i can spend it on tires :P. Please post up a picture and offset please!! :D
Re: CRZ OFFSETS
any help? does anyone know the offset of the stocks?
Re: CRZ OFFSETS
Im running 17x9 +38 in front and 17x9.5 +38 in rear and it required rear bumper mount modification as well as camber in front to fit. Running camber bolts top and bottom.
http://farm7.static.flickr.com/6015/...429bd25a_o.jpg |
Re: CRZ OFFSETS
^^ clean :)
Re: CRZ OFFSETS
Originally Posted by hotboxn
(Post 45950491)
Re: CRZ OFFSETS
front is now 1" lower and rear is 3/4" lower. Swapped out for 215/45 in front and still running 225/45 in the rear.
Re: CRZ OFFSETS
Wow that's sexy I drove one of these at work yesterday for the first time that shit gets it for a hybrid I was very surprised
Re: CRZ OFFSETS
i believe crz has very similar offset of 8th gen civic. ( i guess including 9th gen civic ).
Re: CRZ OFFSETS
(Post 45950491)
Re: CRZ OFFSETS
Should work out with a little bumper mount work and some roll
Re: CRZ OFFSETS
Car looks really good hotboxn. :thumbup:
Re: CRZ OFFSETS
Thx!
Re: CRZ OFFSETS
DAmmmmm ****en sick, like the whole white color theme =]
Re: CRZ OFFSETS
I really, really, like those wheels on the white CRZ! :thumbup:
Re: CRZ OFFSETS
looks sweet
Re: CRZ OFFSETS
Originally Posted by Janet@bisimoto
(Post 46029161)
Re: CRZ OFFSETS
To answer the original question the stock wheels are +45 offset, in either a 6" wide standard or 6.5" wide optional oem wheel. The front wheels are flush at about 15-20mm lower offset than stock, and the rears at 30-35mm. If you want a flush look in back and no poke in front youll have to run spacers in the rear or a staggered setup, since the rears are much more sunk in.
Also if you lower the car on anything wider than stock wheels, you will probably need to run slightly stretched tires, negative camber and/or roll and shave the inside of the fenders. This car is not friendly for aggressive fitments, but it can be done. |
Re: CRZ OFFSETS
someone should do the varrstoens 17x9 +30 !
Re: CRZ OFFSETS
Phizstuh - No Fake Wheels Please!
Car looks good Justin... i'm going with 17x9.5 +38 with 225's all around on my setup... NT03 Hella Flush! - Basis Sport Tony |
Re: CRZ OFFSETS
It'll be fun pulling those fenders w/ 225's and 9.5's. It'll look good though.
Re: CRZ OFFSETS
clean!!!
Re: CRZ OFFSETS
Would I have any problem mounting this size on the rear?
17x9 offset +44 114.3 |
Re: CRZ OFFSETS
Originally Posted by og asr
(Post 46924185)
Re: CRZ OFFSETS
RWD stagger on a FWD? what?
Re: CRZ OFFSETS
Here are some Advan RGII wheels.
17×9.5 +35 all around 215/40f 225/40r This is on one of our riders CRZs. Check out some info and some photos of his car here... Link: http://www.autocityimports.com/blog/2012/cr-z-bagged/ http://www.autocityimports.com/blog/...canibeat-1.jpg |
