Fit 2008 Has Hiccups and Stalled at Red Light
Hello everyone!
I'm new here and it seems I've come to the right place.
I bought a used Honda Fit Sport (2008 Automatic) from a used car dealership here in San Diego exactly 3 months and 3 days ago, so there goes that 90 day warranty. Hurray. While I've gotten used to it downshifting at red lights, making kind of a *thump* noise and feeling, I've noticed over the past week or so that it almost seems like it has the hiccups when stopped at red lights. I counted over fifteen various *thumps* in about a five minute period. Otherwise, it runs perfectly so I thought maybe it was the drastic over 100 degree heat wave we just went through.
However, today as I was stopped, foot on only the brake, it died on me and the battery light and the oil light came on. I was in a panic, so I turned the engine completely off (there were people behind me) and back on. It started again fine, and I was able to get home.
Any idea what could cause this? The CarFax report was clean, and I got it from a certified dealership with killer Yelp reviews! Please help!
I'm new here and it seems I've come to the right place.I bought a used Honda Fit Sport (2008 Automatic) from a used car dealership here in San Diego exactly 3 months and 3 days ago, so there goes that 90 day warranty. Hurray. While I've gotten used to it downshifting at red lights, making kind of a *thump* noise and feeling, I've noticed over the past week or so that it almost seems like it has the hiccups when stopped at red lights. I counted over fifteen various *thumps* in about a five minute period. Otherwise, it runs perfectly so I thought maybe it was the drastic over 100 degree heat wave we just went through.
Your list of symptoms means that your used Fit needs some or all of the following: 1. valve clearance adjustment, 2. new spark plugs, 3. new coil packs.
Since all of that sounds completely Greek, would you recommend a dealership at this point (I'll be begging for the warranty tomorrow since they are closed today), or find a trustworthy auto shop nearby? Also, is it even drivable at this point?
Most Fit owners do not trust dealership repairs or maintenance work because dealerships don't always do good work but always charge too much compared with quality independent shops.
If your Fit has 50K or more on the odometer and you do not have service paperwork showing that the valves have recently been adjusted, then getting them adjusted now will probably cure your symptoms. If it does not, then go on to the plugs and coil packs. You will probably need the plugs and coil packs by the time you get to 100K miles, but they can fail and cause engine misfires at any time with no guarantees on the lifespan of either plugs or coil packs. If you don't have the ability to do this work yourself, then you are looking at a pretty expensive repair bill. It is very unlikely that your selling dealer did any of this work before the sale.
Take a look at any other Fit forum and you will find hundreds of posts concerning the causes and cures for engine misfire (stuttering) conditions.
Good luck! After the engine work is done and the car runs fine again, you should plan on a brake fluid change, auto transmission fluid change, and radiator coolant change based on the age of the car.
Absolutely. Cylinder misfire/stuttering/stalling means that one or more cylinders are not producing the power to turn the crankshaft and unburned fuel is going out the exhaust system.
I have similar problem with my 2007 Fit Sport. I have changed the spark plugs and coil packs, problem is still there. Now I need to connivance my mechanic to do a valve adjustment for me. Last time I told him about it, he said the valve adjustment has nothing to do with this problem.
It's really not hard to do yourself just a bit time consuming and you HAVE to follow directions.
DIY adjusting valve clearences GD - Honda Fit Forums
I have the same problem - my Fit almost stalls when either the AC is on or the Defrost is on. I have alsready spent $600 on this at the dealer and it's still not fixed.
