what gasket set and rear main seal >b16a1
Old 10-15-2004, 05:41 PM
doublethink's Avatar
Default what gasket set and rear main seal >b16a1
i know i suck, but all the rubber wasnt changed when i did the swap.
now i lose coolant every time i drive. its not leaking which means its burning off or worse, in the oil. i dont have a proper length oil stick, so i cant see if theres any in the oil itself. but this is very NOT GOOD also my rear main seal leaks too. this engine is a mess basically and it makes me pissed to think about it. i ran out of money at the time and tried to rush it.
so now i need to make this right, and i will pull the engine if i have to. i basically want to do all the rubber on the engine my budget is about $900 to do so. so if you know part numbers and whatnot please chime in!!. a few b16 swap guides have parts lists but none that answers this question.
1) What seals and gaskets should be changed with a swap?
2) What comes in a "gasket set"?
3) Which gasket set will work for a b16a1?
del sol?
90-91 integra?
thanks in advance!
Old 10-15-2004, 06:06 PM
Default Re: what gasket set and rear main seal >b16a1 (doublethink)
anyone got some love for a cheater who wants to make ammends!
NO MORE CORNER CUTTING!
::smacks self in head::
Old 10-15-2004, 07:25 PM
88DXCRX's Avatar
Location: I told you to wait in the truck in Texas, United States
Everything I replaced came from the top list marked >,
Thanks to member "Monty" for the info:
>Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orifice O-ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
Throttle Body Gasket 16176-PR3-010 90-91 integra
PCV valve 17130-PM6-G01 94 - del sol
>Timing Belt 14400-PR3-004 94 - del sol
>Alternator Belt
[I used a NAPA 25-040300]
>Tensioner 14510-P30-003 94 - del sol
>Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O-rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
>Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
>Clutch Cable 22910-SK7-A02 90-91 integra
>Throttle Cable 17910-SK7-A03 90-91 integra
>Cam Seals (2) 91213-PR3-004 94 - del sol
>Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
good luck finding The above number try..NAPA 1334
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Shift linkage bushing 54303-SB2-010 90-91 integra
>91006-634-008 >pilot bearing
>22810-PS1-015 >throwout bearing
>crank seal 91212-PR3-003 94 - del sol
>rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
>Valve cover grommets (8) 90442-P30-000 94 - del sol
>Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
>Spark Plugs (4) BKR6E-N11 NGK
>Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
>FOR HOSES:Two NAPA #8561 will work if cut right..
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
Other info found:----??????
Axles (S1 intermediate shaft) Integra '90-'91, any make (non-ABS).
Throttle Cable '90-'91 Integra, any model. Part # 17910-SK7-A03 (Acura)
Clutch Cable '88-'91 CRX Si, may require modification to fit.
Shift Linkage + Torque Rod '90-'93 Integra, requires modification to fit, or buy pre-cut (highly advised)
Clutch Disc Integra non-GSR, '90-'91.
Clutch Plate Integra non-GSR, '90-'91 (?????)
Throwout/release bearing Integra GSR, '92-'93 (?????)
Flywheel bearing Integra GSR, '92-'93 (?????)
Cam seal endplug Part # 12513-P30-000
Oil Filter Integra GSR, '92-'93.
Valvecover Gasket Part # 12341-PR3-000. del Sol VTEC '94+.
Oil Pan Gasket Part # 11251-P30-004, del Sol VTEC '94+.
Intake Manifold Gasket Part # 17105-P30-004, del Sol VTEC '94+.
Exhaust Manifold Gasket Part # 18115-P30-013, Del Sol VTEC, '94+.
Rear coolant hose (IACV?) Part # 19507-PR3-000 (Honda)
Cam Seals Part # 91213-PR3-013 (Honda)
Cam seal endplug Part # 12513-P30-000 (Honda)
Spark plug tower seals Part # 12342-PG6-000 (Honda)
Valve cover grommets Part # 90442-P30-000 (Honda)
Timing belt cover gasket Part # 11831-PR3-000 (Honda)
Head gasket del Sol VTEC '94+
Fuel injector O-rings Part # 91301-PM7-003, del Sol VTEC '94+
Fuel injector rail cushions Part # 16473-PD6-000, del Sol VTEC '94+
Distributor Cap and Rotor Integra non-VTEC kit from Acura ('90-'91 Integra LS) Part # 06303-PR4-000
Water Pump Part # 19200-P30-003, from a '92-'93 Integra GSR.
Front + Rear Crank Seal Integra GSR, '92-'93.
Throttle body gasket Integra LS, '90-'91 (????). del Sol VTEC does NOT fit.
IACV seal CRX Si, part # 36455-PR4-A01
IACV CRX Si
Upper + Lower Radiator Hose del Sol VTEC, '94+.
Timing Belt Part # 14400-PR3-004, del Sol VTEC '94+.
Spark Plugs Part # BKR6E-11 (NGK copper) GAP: 0.039-0.043
Rear Transmission Bracket Part # 50827-SK7-020, '90-'93 Integra non-VTEC (80% sure)
Coolant hose, back of block to intake manifold Part # 19507-PR3-000, del Sol VTEC '94+.
For some more numbers also see:
http://honda.hybrids.jp/tech/p...shtml
Modified by 88DXCRX at 3:50 PM 3/21/2005
Old 10-15-2004, 07:48 PM
Default Re: what gasket set and rear main seal >b16a1 (88DXCRX)
two things,
first....thanks!
second.... add that to the FAQ topic!!
Old 10-15-2004, 08:00 PM
88DXCRX's Avatar
PS
Info on belts that worked for me:
https://honda-tech.com/zerothread?id=1024059
Old 10-15-2004, 08:22 PM
lol a/c ?? damn i was too afraid to hook that up. i just ripped it all out. ghetto style, must be a new york thing. its really only HOT for like 30-40 days here to miss it.
btw, you rule.
deeboi
01-21-2013 10:25 PM
ThaBread
18
11-02-2008 09:32 AM
TOO MUCH TORQUE
07-10-2008 02:26 PM
GSR_hatch936
14
10-30-2007 11:09 AM
brnzbuddha
01-29-2005 08:48 AM
Quick Reply: what gasket set and rear main seal >b16a1
