what gasket set and rear main seal >b16a1
i know i suck, but all the rubber wasnt changed when i did the swap.
now i lose coolant every time i drive. its not leaking which means its burning off or worse, in the oil. i dont have a proper length oil stick, so i cant see if theres any in the oil itself. but this is very NOT GOOD https://honda-tech.com/forums/images/smilies/emsad.gif also my rear main seal leaks too. this engine is a mess basically and it makes me pissed to think about it. i ran out of money at the time and tried to rush it. so now i need to make this right, and i will pull the engine if i have to. i basically want to do all the rubber on the engine my budget is about $900 to do so. so if you know part numbers and whatnot please chime in!!. a few b16 swap guides have parts lists but none that answers this question. 1) What seals and gaskets should be changed with a swap? 2) What comes in a "gasket set"? 3) Which gasket set will work for a b16a1? del sol? 90-91 integra? thanks in advance! |
Re: what gasket set and rear main seal >b16a1 (doublethink)
anyone got some love for a cheater who wants to make ammends!
NO MORE CORNER CUTTING! ::smacks self in head:: |
Everything I replaced came from the top list marked >,
Thanks to member "Monty" for the info: >Water Pump 19200-P30-003 94 - del sol Head Gasket 12251-P30-014 94 - del sol Oil Control Orifice O-ring 15142-PH3-003 94 - del sol Intake Manifold Gasket 17105-P30-004 94 - del sol Exhaust Manifold Gasket 18115-P30-013 94 - del sol Throttle Body Gasket 16176-PR3-010 90-91 integra PCV valve 17130-PM6-G01 94 - del sol >Timing Belt 14400-PR3-004 94 - del sol >Alternator Belt [I used a NAPA 25-040300] >Tensioner 14510-P30-003 94 - del sol >Thermostat 19301-P08-305 90-91 integra / 94 del sol (same) Connecting Pipe O-rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same) >Cap & Rotor Assembly 06303-PR4-000 90-91 integra Rotor (If needed seperately) 30103-PR3-016 90-91 integra >Clutch Cable 22910-SK7-A02 90-91 integra >Throttle Cable 17910-SK7-A03 90-91 integra >Cam Seals (2) 91213-PR3-004 94 - del sol >Oil pan seal 11251-P30-004 94 - del sol Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol Oil Filter 15400-POH-305 94 - del sol good luck finding The above number try..NAPA 1334 Oil Pick Up Gasket 15221-PW0-S01 94 - del sol Shift linkage bushing 54303-SB2-010 90-91 integra >91006-634-008 >pilot bearing >22810-PS1-015 >throwout bearing >crank seal 91212-PR3-003 94 - del sol >rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same) >Valve cover grommets (8) 90442-P30-000 94 - del sol >Spark Plug O rings (4) 12342-P66-000 94 - del sol Rubber plug for exhaust cam tranny side 94 - del sol >Spark Plugs (4) BKR6E-N11 NGK >Spark Plug Wires 32722-PR4-A01 92 - integra gsr Upper Radiator Hose 19501-PR3-000 92 - integra gsr Lower Radiator Hose 19502-PR4-A00 90-91 integra >FOR HOSES:Two NAPA #8561 will work if cut right.. Bypass Hose (Thermostat) 19508-P08-000 94 - del sol Washer for coolant drain on block 90401-PR4-000 94 - del sol Other info found:----?????? Axles (S1 intermediate shaft) Integra '90-'91, any make (non-ABS). Throttle Cable '90-'91 Integra, any model. Part # 17910-SK7-A03 (Acura) Clutch Cable '88-'91 CRX Si, may require modification to fit. Shift Linkage + Torque Rod '90-'93 Integra, requires modification to fit, or buy pre-cut (highly advised) Clutch Disc Integra non-GSR, '90-'91. Clutch Plate Integra non-GSR, '90-'91 (?????) Throwout/release bearing Integra GSR, '92-'93 (?????) Flywheel bearing Integra GSR, '92-'93 (?????) Cam seal endplug Part # 12513-P30-000 Oil Filter Integra GSR, '92-'93. Valvecover Gasket Part # 12341-PR3-000. del Sol VTEC '94+. Oil Pan Gasket Part # 11251-P30-004, del Sol VTEC '94+. Intake Manifold Gasket Part # 17105-P30-004, del Sol VTEC '94+. Exhaust Manifold Gasket Part # 18115-P30-013, Del Sol VTEC, '94+. Rear coolant hose (IACV?) Part # 19507-PR3-000 (Honda) Cam Seals Part # 91213-PR3-013 (Honda) Cam seal endplug Part # 12513-P30-000 (Honda) Spark plug tower seals Part # 12342-PG6-000 (Honda) Valve cover grommets Part # 90442-P30-000 (Honda) Timing belt cover gasket Part # 11831-PR3-000 (Honda) Head gasket del Sol VTEC '94+ Fuel injector O-rings Part # 91301-PM7-003, del Sol VTEC '94+ Fuel injector rail cushions Part # 16473-PD6-000, del Sol VTEC '94+ Distributor Cap and Rotor Integra non-VTEC kit from Acura ('90-'91 Integra LS) Part # 06303-PR4-000 Water Pump Part # 19200-P30-003, from a '92-'93 Integra GSR. Front + Rear Crank Seal Integra GSR, '92-'93. Throttle body gasket Integra LS, '90-'91 (????). del Sol VTEC does NOT fit. IACV seal CRX Si, part # 36455-PR4-A01 IACV CRX Si Upper + Lower Radiator Hose del Sol VTEC, '94+. Timing Belt Part # 14400-PR3-004, del Sol VTEC '94+. Spark Plugs Part # BKR6E-11 (NGK copper) GAP: 0.039-0.043 Rear Transmission Bracket Part # 50827-SK7-020, '90-'93 Integra non-VTEC (80% sure) Coolant hose, back of block to intake manifold Part # 19507-PR3-000, del Sol VTEC '94+. For some more numbers also see: http://honda.hybrids.jp/tech/p...shtml Modified by 88DXCRX at 3:50 PM 3/21/2005 |
Re: what gasket set and rear main seal >b16a1 (88DXCRX)
two things,
first....thanks! second.... add that to the FAQ topic!! https://honda-tech.com/forums/images...es/emsmile.gif |
lol a/c ?? damn i was too afraid to hook that up. i just ripped it all out. ghetto style, must be a new york thing. its really only HOT for like 30-40 days here to miss it. https://honda-tech.com/forums/images...es/emsmile.gif
btw, you rule. https://honda-tech.com/forums/images/smilies/emthup.gif |
