trouble with cod start
hi there im new to the forum and to hondas i have a few problems i got an 1988 crx si with a zc in it( part of a trade) it runs fine when warmed up but i have trouble starting in the mornings or when has been sitting for more than 6 hours.
im geting codes 6,9,10
ecu is a pm7
i have tried new water sensor as old was in a state but still has not fixed the code 6 whitch is causing the cold start problem as far as i can tell(just from what ive read on here) any ideas?
ecu is a pm7
Re: trouble with cod start
have tried still same ol story i have some pics of some wiring from ecu into the engine bay plug the wires for the sensor are in a multi wire cable with outer wire a few are like it and they are joind up to a brown wire ant the ecu end but at the other end are a no go to anyware the are just open ended.
the blue wire you can kind of see is much like tv coax cable except has 4 wires on the inside then coverd by mesh wire on the outer before the blue
existanzcivicb20
05-15-2015 03:35 PM
