trouble with cod start
Old 06-20-2009, 03:16 PM
New User
kaleb10's Avatar
Default trouble with cod start
hi there im new to the forum and to hondas i have a few problems i got an 1988 crx si with a zc in it( part of a trade) it runs fine when warmed up but i have trouble starting in the mornings or when has been sitting for more than 6 hours.
im geting codes 6,9,10
ecu is a pm7
i have tried new water sensor as old was in a state but still has not fixed the code 6 whitch is causing the cold start problem as far as i can tell(just from what ive read on here) any ideas?
Old 06-20-2009, 04:10 PM
90honduh's Avatar
Default Re: trouble with cod start
try resetting your ecu. pull the cables off your battery for like a minute
Old 06-20-2009, 05:44 PM
New User
kaleb10's Avatar
have tried still same ol story i have some pics of some wiring from ecu into the engine bay plug the wires for the sensor are in a multi wire cable with outer wire a few are like it and they are joind up to a brown wire ant the ecu end but at the other end are a no go to anyware the are just open ended.
Old 06-20-2009, 06:10 PM
New User
kaleb10's Avatar
[/IMG]w.honda-tech.com/picture.php?albumid=14504&pictureid=28534[/IMG]
Old 06-20-2009, 06:11 PM
New User
kaleb10's Avatar
New User
kaleb10's Avatar
Old 06-20-2009, 06:12 PM
New User
kaleb10's Avatar
the blue wire you can kind of see is much like tv coax cable except has 4 wires on the inside then coverd by mesh wire on the outer before the blue
Old 06-20-2009, 06:13 PM
New User
kaleb10's Avatar
dont know if you can tell whats going on there but hpfully someone can help
Old 06-20-2009, 08:05 PM
Matt6387's Avatar
im pretty new to these honda's but it might help if you drew a diagram in paint and label it well, might help
Old 06-20-2009, 09:08 PM
New User
kaleb10's Avatar
trying to explain
Old 06-21-2009, 12:56 AM
skipbudlong's Avatar
wow, the colors.
Harrymonk
06-21-2018 11:25 AM
existanzcivicb20
05-15-2015 03:35 PM
zCivic
05-11-2002 11:59 AM
Quick Reply: trouble with cod start
