temperature not working on cluster!!
temperature is not working on the cluster. everytime i turn the key on, it moves down instead of going up... and when the engine is fully warm it doesn't go up at all... anyone has a diagram of the coolant temperature wire? and is there more than one temperature sensor??
Re: temperature not working on cluster!! (ef8sleepr)
the sensor should be under the dizzy check to make sure its plugged in. i have the same swap and mine came unplugged once and did the same thing
Yoitshector
35
02-27-2013 03:12 AM
