Cluster help
so my rpm/speedometer arent working on my usdm itr cluster.
had the cluster for over a year now and this problem just started to occur.
when ever i hit a bump on the streets while rolling the rpms would jump i thought there was something loose in the back of the cluster and nothing, i checked all the fuses, everything was good and yes even checked the speed sensor. now im just starting to think that cluster went bad.
Any help on this would be appreciated
PS everything else works fine its just the rpms/Speedometer
I just looked at it to see if the pins were rusted or anything since I don't have a volt meter but idk cause my check engine light or oil light don't turn on either.
and @fcm its a 98 and so is the cluster. but the green film is from a jdm itr cluster that i use have from the same year if thaat makes a difference
Pull the cluster and check for power on the yellow lead in cluster plug, with ign. switch on.
Check for ground on the black leads.
It is best if you you use a 12V test light, [not LED type] as it will put a load on the line a meter or LED type test light will not. 94
qm8888
Apr 3, 2008 09:05 PM
