Need wiring help with gsr swap in ef wagon
Old 06-18-2009, 07:57 PM
helpmycivic's Avatar
Default Need wiring help with gsr swap in ef wagon
ok so i have a 89 ef wagon and i just put a b18c1 into it. i did the dpfi to mpfi swap and everything was done right. the problem that im having is that im not getting spark and im not sure why. ive tried 2 ecu's and 2 dizzy's just to make sure and all are known working parts but still no spark. ive tripple checked my wiring and everything is right and i cant figure out why im not getting spark. ive checked all fuses and anything else i could think of so if anyone else has any ideas please let me know. ive searched for hours as well so yes i did search before posting this. thanks
Old 06-18-2009, 09:04 PM
+honda_monkey+'s Avatar
Default Re: Need wiring help with gsr swap in ef wagon
wow gsr wagon. id like to c that. i was going b16 in mine but nahh. i want my sedan back. gl gettin it running
Old 06-18-2009, 09:05 PM
btw them guys over at www.hondacivicwagon.com know alot
Old 06-18-2009, 09:23 PM
yea it should be pretty fun when its done. and thanks for the website ive never been to that one yet haha ill def check them out.
Old 06-18-2009, 11:04 PM
My_EFsedan's Avatar
how are you running the gsr? obd0?
the mpfi, double check all the wires.
add 2 injector clips
all 4 red/black ground wires to resister
c1>b10
c2>b12
c1/c2 to engine
swap dx dizzy plug to Si
c1 is blue/green on dizzy
c2 is blue yellow on dizzy.
injector 2 >A3
injector 4 >A7
swap tps wires
i remember i did a mpfi awhile ago and i forgot the dizzy wires..once thats done it ran
Old 06-18-2009, 11:32 PM
yea i got all that done. im running everything obd0. i think i may have figured my problem though. i am using a jdm ef9 engine harness and i just read that the ignitor wire and some other wires in the harness are not pinned the same as on the dx harness? if anyone can verify that i would appreciate it. im gonna wire up the dual point harness tomarrow and hope that everything works. thanks for the help.
Old 06-19-2009, 12:04 AM
My_EFsedan's Avatar
the Dx harness? no im sure they are different. use the DX harness and do the mpfi on there. i bet you the car will run.
it would plug and play it the car trim was an Si.
Old 06-19-2009, 12:12 AM
^^ your the reason why my first honda was an EFsedan. and now your still the reason why i want it back. lol i hate you
Old 06-19-2009, 12:15 AM
im gonna pull the jdm sir harness off tomarrow and put the dx harness on and wire it all up so hopefuly it will work when im done. i didnt realize that the chassis harnesses were different between dx, hf, si and so on. thanks for the help.
Old 06-19-2009, 12:21 AM
haha yea i love my wagon, cant wait to get it running now! im getting really impatient haha hopefully it will be done tomarrow! im a ef lover and always will be
90Attack
13
10-19-2011 02:56 PM
shervang9
28
03-16-2011 12:00 AM
JDMmadness
02-18-2010 01:43 PM
JDMmadness
02-13-2010 04:10 PM
CoLJeW
12-18-2001 05:54 AM
Quick Reply: Need wiring help with gsr swap in ef wagon
