b16 Engine coolant temperature Help
hi guys im new to these boards and it looks like theres alot of help here. so here goes, ok the car is not ever heating, i replaces the radiator fan switch (the one that goes in the thermostat housing) and i replaced the coolant temp sensor which is in the side of the head and im still getting the code the light is blinking 6 times in a row and then stops and does it all over again.
thanks for any help in advance
Re: b16 Engine coolant temperature Help
thanks for the reply i tried that and i ran the car, refilled the water that leaked out all the bubbles out of the radiator, i disconnected the batter for an hour or more, while i went to sleep and took out the backup fuse also. i also tried unplugging the ecu as well, and im still getting it
what does the code say? beside 6 times? i never heard of a cel for temp problem, or i could be just out of it. I would try this, take the single wire that goes to the temp sending unit in your head and ground it. Turn on the car and see if the temp guage moves up. Do not let it sit there you have to be some what quick on the draw so you dont **** up the guage.
never had any codes before but i recently took out the engine to replace all gaskets and seals because it was leaking oil and i wanted to check all the internals and all are fine but im stuck with this light for now
Haha thats great... only because I just did the exact same thing acouple weeks ago after dropping in my rebuilt motor. :p
eghatchfla
05-31-2010 07:17 PM
Project_ED8
24
11-22-2003 12:16 AM
MikeMAN
07-29-2003 02:24 AM
