GIVE ME HOPE, PLEASE LOOK!!!
I have a d15,y8 mini-me! It cranks starts up then quickly dies! I can keep it alive if i keep giving it gas! I need to get it running tonight and if it dosnt start up i have a DX (96) i am gonna swap in! So please any advice!
Re: (****S OF HAZARD)
Dude sounds like a wiring issue if you only throw those codes sometimes. You need to get it to stop throwing those codes and It should run if your cam timming is on and your getting air fuel and spark cand propper compression.
Blaze
Blaze
Re: (Blaze45)
Well i cant see any wiring problems! I dont know i think i am just gonna fire the damn thing! Speaking of cam timing i am i just gonna align it like i would a normal setup would be or do i have to move it a certain number of teeth back or fourth!
Keep backing out the idle screw. See if you can't get it to hold idle. If you have to, remove the brake booster hose from the intake manifold to create a massive air leak. If it doesn't run with such a huge air leak you've got bigger mechanical problems.
DevinW
06-06-2002 02:21 PM
