Throttle seems to stick and CEL comes on...any ideas?
Old 05-22-2002, 05:59 AM
DevinW's Avatar
Default Throttle seems to stick and CEL comes on...any ideas?
Hey guys,
My throttle seems to 'stick' at around 3000 RPM. Then when I give it a little gas, it will come back down.
I adjusted the idle screw and got the idle down as far as I could: 1500 RPM. After it idles for a long while, the CEL will come on. Then if I shut the car off, it will go away. Any ideas?
I have yet to get the CEL codes from the computer...I'm going to try again tonight.
Thanks!
Old 05-22-2002, 06:06 AM
spoon_ek9's Avatar
Default Re: Throttle seems to stick and CEL comes on...any ideas? (DevinW)
your tps migt got something wrong, check your cel code.
Old 06-06-2002, 01:56 PM
btlfedhatch's Avatar
Default Re: Throttle seems to stick and CEL comes on...any ideas? (spoon_ek9)
You also wanna check your Throttle Cable Deflection, look between the TB and the Throttle Cable Hanger, and you should have 12mm of play, your Cable may be too tight causing your idle to be high. Take a 12mm open end wrench and eye ball the Throttle Cable in the middle of the wrench and wiggle the Throttle Cable to check it. If there isn't enough slack then on the Throttle Cable Hanger, loosen the 12mm nut and put some slack in the Cable.
Old 06-06-2002, 02:21 PM
navin's Avatar
I have the same problem - im too lazy to deal with it. New motor soon anyway..
Jaymon
14
05-24-2015 11:59 PM
Team PHATBOYZ
06-17-2010 01:56 PM
bseries_beast
07-02-2004 09:25 PM
blunty
04-22-2002 07:51 AM
integra99blue
07-16-2001 07:56 PM
Quick Reply: Throttle seems to stick and CEL comes on...any ideas?
