Civic CV joints and axles???
Old 04-01-2002, 01:10 PM
Veil_Side_'s Avatar
Default Civic CV joints and axles???
Okay, just before I go, I want to make sure I buy the right parts.
Car makes clicking sound when I go left, someone told me that it is the right CV joint. I have a 91 Civic DX, is that 23 or 26 splines????
Second, should I buy the CV boot or the entire right axle?
Old 04-01-2002, 01:13 PM
Urban Business
Guest
Posts: n/a
Default Re: Civic CV joints and axles??? (Veil_Side_)
eah usually when it clicks its the opposite of what direction your turning from. incpect the axles and boots tho. just but a new axle. you can regrease joint and put new boot on but thats a short term solution. and i thought a 90 dx has 21 splines. check it out on carparts.com to make sure
Old 04-01-2002, 03:47 PM
EP3_05's Avatar
Just buy a new axle. If the joint is clicking then most likely it is already on it's way out.
[Modified by 91civic, 7:47 PM 4/1/2002]
Old 04-01-2002, 03:51 PM
june's Avatar
Default Re: Civic CV joints and axles??? (91civic)
Yeah go buy a new axle. That's when you know you need a new axle.
Old 04-01-2002, 05:40 PM
New User
Whataricky's Avatar
get the whole axle. hell do both that way you dont have anymore axle problems. I know RAXLES.com used to give crxr's a discount on stock axles I think they were $110 for each side. But install is simple do it yourself
Old 04-02-2002, 04:37 AM
D Tranny Guru
Mista Bone's Avatar
Civic STD and CRX HF got the 23 spline (puny) axles. Take your old axle with you to Autozone and match them up. Also saves a trip to return the core.
BTW if you can afford it, buy both axles.
chris89
Transmission & Drivetrain
08-28-2015 09:51 PM
EJ8 GSR-T
05-17-2007 07:19 PM
mingbling96
03-13-2005 08:14 AM
NstyGrnHatch
10
02-15-2005 11:35 AM
arren123
04-13-2003 12:54 PM
Quick Reply: Civic CV joints and axles???
