91 SI tranny wont shift in reverse
Old 12-12-2011, 06:54 PM
StayTunedEf's Avatar
Default 91 SI tranny wont shift in reverse
i recently did a 5 speed swap in my 89 hatch and at first the tranny shift through all gears put it in reverse tested it it worked couple min later i went to take it out and it wouldnt go in reverse i thought it was my b*tch pin cause it was half broke so i replaced it and it work for one try then stoped now i cant get it into reverse at all its like hitting a wall but the car drives fine ??? idk what to do anyone got anything?
Old 12-12-2011, 11:06 PM
EFB055
~sp33~'s Avatar
Default Re: 91 SI tranny wont shift in reverse
If it worked before, re check all your linkages. That's going to be the most likely problem.
Old 12-16-2011, 06:22 AM
i think it might be the shift fork so im going to retear the tranny out and open it up cause its like its just hitting a brickwall no give at all
Old 10-24-2012, 10:26 AM
hondatime1's Avatar
Did you find out cause?
~Bob
Ge-money
18
11-18-2006 05:43 PM
jvo8
09-07-2005 09:40 PM
DV98CVC
02-21-2003 06:38 AM
DOHCarp
06-08-2002 04:49 PM
Quick Reply: 91 SI tranny wont shift in reverse
