12- EGR - exhaust gas recirculation lift valve
does anyone have any idea, of how to correct this code? i did search, but got no answer. if you have any clue on this, please let me know!
Re: 12- EGR - exhaust gas recirculation lift valve (smokey2.0)
Code 12 - Exhaust Gas Recirculation System
Mounted on the right back corner of the fire wall. It cannot be purchased seperatly, but only as a unit. Voltage range of the lift sensor is 1.2v closed to 4.0v open. It was required on all cars sold in in CA. starting in 1988. However, some CIVIC's were engineered without having to use one, to control NOx.
Purge Control Wires:
1 Yellow/Black
1 Red/Yellow
Back
Try cleaning it out
1 Yellow/Black
1 Red/Yellow
Back
Try cleaning it out
Re: 12- EGR - exhaust gas recirculation lift valve (HT Chaplain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain »</TD></TR><TR><TD CLASS="quote">i have the same problem How can you eliminate the code???</TD></TR></TABLE>i guess by either cleaning it or taking it off, i'll find out tonight when i try cleaning it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 »</TD></TR><TR><TD CLASS="quote">i guess by either cleaning it or taking it off, i'll find out tonight when i try cleaning it!</TD></TR></TABLE>
i made a fuel saver and did a MPFI conversion in my STD so i could use my old HF motor and the STD doesnt have a way to hook up the EGR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain »</TD></TR><TR><TD CLASS="quote">i made a fuel saver and did a MPFI conversion in my STD so i could use my old HF motor and the STD doesnt have a way to hook up the EGR </TD></TR></TABLE>post some pictures, i probably won't have any time to play with this until the weekend!
