Z6 Y7 Mini me timing problems. NO START
Old 03-17-2011, 08:53 AM
  #51
thecruzs2007@yahoo.com's Avatar
Default Re: What are some of the MAIN problems everyone has with MINI ME swaps
y8 head gasket is best for higher compression..that and its metal
Old 03-20-2011, 04:40 PM
  #52
PardonmyEK9's Avatar
Default Z6 Y7 Mini me timing problems. NO START
i just put a z6 head on my y7 block and it wont start. everything is at TDC. i have a notched out y7 dizzy and z6 cam gear with a y8 timing belt. p28 ecu. does anyone have any ideas what i should look for or try to do?
i also heard that you can only get correct timing with a z6 head on a 1.5 block?? is this true??
Old 03-20-2011, 04:47 PM
  #53
Former User's Avatar
Default Re: Z6 Y7 Mini me timing problems. NO START
Spark, fuel, compression, CEL codes?
Old 03-20-2011, 04:48 PM
  #54
The Grumpiest
grumblemarc's Avatar
Beware to anyone thinking of responding.
This is your FOURTH post about this same mini-me swap. I told you in your FIRST thread to try and stick to a proven guide and parts list and NOT Frankenstein parts together that were not on the list and you did anyway. Why you even started that post then is beyond me if you weren't going to take people's recommendations. Now you have problems and you won't listen to anything anyone is telling you.
For your timing issues people have told you many times to get an adjustable cam gear.
https://honda-tech.com/forums/showthread.php?t=2906930
https://honda-tech.com/forums/showthread.php?t=2901393
https://honda-tech.com/forums/showthread.php?t=2910577
Old 03-20-2011, 04:59 PM
  #55
TaffetaEj6's Avatar
simply priceless how you totally called it on the swap being a failure on his other thread.
Old 03-20-2011, 05:05 PM
  #56
The Grumpiest
I quote
Originally Posted by PardonmyEK9
And what about notching the ears on the y7 dizzy does that work or is just a waste of time?
Originally Posted by 94EG8
You really can't set the timing properly, plus it looks really ghetto.
And he did it anyway.
Just one example.
Old 03-20-2011, 05:09 PM
  #57
209 DoC's Avatar
check all ur grounds make sure batt is charged and has 12.6v
Old 03-20-2011, 05:10 PM
  #58
The Grumpiest
How does that fix the timing issue?
Old 03-20-2011, 05:22 PM
  #59
Four related threads merged.
Old 03-23-2011, 05:01 PM
  #60
chope045's Avatar
you cant get it to run b/c you have a non vtec dizzy on a vtec head i had the same problem get a z 6 dizzy and it will run
Old 03-23-2011, 05:04 PM
  #61
ddd4114's Avatar
I'm running a non-vtec distributor on a vtec head right now. It's fine. However, it needs some "modifications".
You can also run the car even if it's horribly out of phase. It will run horribly, but it will run nonetheless.
dohdoh420
23
10-20-2005 05:56 PM
mr. carpenter
04-01-2005 07:40 PM
LegendLS95
10
10-18-2001 07:45 AM
Quick Reply: Z6 Y7 Mini me timing problems. NO START
