wiring up for b16a sir2 into 94 cx
im half way done doing my b16a sir2 swap into my 94 cx
i want to make sure i have all the wiring correct using my stock cx harness
i need the following wiring to do
3 vtec wires
1 knock sensor
1-4 wire o2sensor
someone told me i would need to do the map sensor too?
if i let out any other wiring to do please let me know
3 vtec wires
1 knock sensor
1-4 wire o2sensor
Re: wiring up for b16a sir2 into 94 cx (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">im half way done doing my b16a sir2 swap into my 94 cx
3 vtec wires
1 knock sensor
1-4 wire o2sensor
if i let out any other wiring to do please let me know</TD></TR></TABLE>
you will need to add;
2 VTEC wires (signal and oil pressure)
1 knock sensor (if you're using a P30, a P28 does not need this)
1 O2 heater signal, other two wires connect under the hood and you use the existing O2 signal wire.
3 vtec wires
1 knock sensor
1-4 wire o2sensor
coffee_junkee
12-14-2008 03:13 PM
Tad
14
06-29-2004 09:22 AM
