Wiring Vtec into a 92 Cx
I need some help on wiring vtec into my 92 cx, i know i need to run wires from the solenoid and the knock sensor, but do i run then into the wire harnes or stright to the ecu? and what pins at the ecu do i use for the vtec and knock sensor? Email me at robest08@hotmail.com. Thanks Rob
Banned
Re: Wiring Vtec into a 92 Cx (Ruckus138)
ALL 92-95 Hatches are pre-wired for vtec. No need to run wires, only wire u should run is a knock sensor wire(if your doing a gsr swap).
[Modified by blykins, 4:05 AM 9/27/2002]
Re: Wiring Vtec into a 92 Cx (blykins)
liam
Re: Wiring Vtec into a 92 Cx (liam821)
You are incorrect!! All the 92s had wiring for VTEC. But the 93-95 only the SI/EX/VX had vtec wiring..the rest didnt.
liam
liam
Ok. ALL 92 models had Wiring for Vtec.
BUT 93-95 CX and DX did not.
Correct?
Correct?
liam
Correct?
Correct?
honda said "wait! we can save 3 cents per car! take that vtec wire off"
Re: Wiring Vtec into a 92 Cx (KAMiN)
liam
BLYKINS
if you don't know what in the hell you are talking about KEEP YOUR DAMN MOUTH SHUT. This is the Kind of **** that makes all the NooBs on here sound like IDIOTS. Because you are giving people WRONG INFORMATION. Damn if you don't know what you are talking about DON'T POST .
Only 92 Hatches WERE ALL wired for VTEC 92 model ONLY and that is the GOSPEL.
BLYKINS
Banned
Re: Wiring Vtec into a 92 Cx (Extreme_Hybrid_Hatch)
BLYKINS
BLYKINS
[Modified by blykins, 6:03 AM 9/27/2002]
Not perfect but please don't give out misleading information. If you are not sure let them know what you think but tell them you arent sure.
Banned
[Modified by blykins, 6:08 AM 9/27/2002]
Re: Wiring Vtec into a 92 Cx (Steve Berman)
the 92 cx canadian version is wired for vtec...i cant remeber what pins exactly are the vtec wires...ill get back to you on that one if i figure it out...im not gonna guess cause i dont want to give misleading Info!!!!!
I may be wrong but I think If your car was made in Canada it is already prewired regaurdless of year. My 93 Canadian CX had a VTEC wire. All I needed was knock
Banned
Re: Wiring Vtec into a 92 Cx (Elite Hatch)
Can anyone back this up on the Civic's from Canada? I need to figure out how to wire vtec in for my GSR motor when I get it
1 Post
My stepbro has a 94 DX and it was made in canada, so he probably has a vtecwire already.
