Wire Harness Question
I just bought a 00 Si that was rearended and I wanted to know if it is possible to take the engine harness out of it and use it with the swap into my 93 CX or is it easier to use the existing wires in the CX and just andd the wires as needed.
Re: (_randeEe)
use the cx harness and change the injector clips, alternator plug, and distributor plugs.
I dont know how you would use the obd2 Si harness b/c it goes all the way throught the firewall(one piece harness) you'll have to convert to 4 wire o2 aswell (get a dx harnes already converted to 4 wire dime a dozen) and run vtec wires to the ecu. thne get a p28 and chip it or run a p30(b16 sol ecu)
Re: Wire Harness Question (spooncivic01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncivic01 »</TD></TR><TR><TD CLASS="quote">I just bought a 00 Si that was rearended and I wanted to know if it is possible to take the engine harness out of it and use it with the swap into my 93 CX or is it easier to use the existing wires in the CX and just andd the wires as needed.</TD></TR></TABLE>
like someone else said, the 5th gen harness is 2-piece, the 6th is 1 piece. you can't interchange them. just curious, how badly was this si rear-ended, and how much did you pay for it?
ben1284
04-16-2008 07:06 AM
b20beast978
23
06-11-2007 09:52 AM
ej1 pilot
12-21-2004 04:34 PM
